Home Forums Sign Making Discussions Vinyl uniform cadet print running off
  • uniform cadet print running off
    Posted by signsni on 17 August 2011 at 12:36
    Hi prints on my sp540 r running off line and text is blurred, is there an easy solution, r do i need an engineer ?
    Jamie Dale replied 14 years, 2 months ago 4 Members · 6 Replies
  • Gary Birch
    17 August 2011 at 12:38
    Sounds like your encoder strip. I would start by giving it a wipe.
    Gary
  • signsni
    17 August 2011 at 12:45
    Hi gary have tried that, seems to be doing it only on certain jobs, one job for some reason will not export some of the text as an eps when i delete some lines it exports ok. i export as a jpg to try and get job done would this be the reason ???? I wouldnt be the brightes spark around the machine !!
  • Stephen Morriss
    17 August 2011 at 14:20
    Only time I’ve had that it was a dirty encoder strip, make sure you’ve cleaned it properly all the way along.
    Don’t use a solvent either, just a clean cloth or I use the cleaning swabs with nothing on.
    JPG shouldn’t be a problem.
  • Gary Birch
    17 August 2011 at 15:46
    As Stephen says file format shouldn’t be an issue. Try taking the encoder strip out and turn it upside down(after cleaning it that is)or maybe the sensor which reads the encoder strip is faulty.
    Gary
  • signsni
    19 August 2011 at 09:24
    hi guys thanks for your help, i have cleaned the strips but the clear strips are very grumpy were could i get new ones ? machine still running off and i have lost manual !!
  • Jamie Dale
    19 August 2011 at 11:31
    hey,
    I had this problem last month except all my prints were shifting colours, if this is only doing with certain file formats its highly unlikely that its the linear strip, although when my encoder strip was on its way out it done it ever so often but eventually packed in, I wouldn’t really recommend cleaning it at all since a compatible strip is only approx 30quid from tech8.eu . Well it was for me the last time I looked, all you need to do is cut to fit your printer.
    If you can get into service mode on your machine, run your linear encoder calibration test, if this fails you know that it’s either your strip or the sensor.
    strip approx 30quid, sensor approx 60quid.
    if your going original… strip is approx 250 from roland
