Home Forums Printing Discussions Uniform Printers Uniform cadet plus print problem
  • Uniform cadet plus print problem
    Posted by Sharon Thornton on 31 May 2013 at 15:45
    Bought this uniform cadet second hand last week, red and yellow rest print was fine but nothing through blue and black. Spent time cleaning blue and black print head got blue almost fully clear and black well on its way then suddenly nothing through that print head at all. Suspect fuse has blown as some people have mentioned in other posts can anyone explain where the fuses are or show me on a picture or any other ideas for the fault.
    The blue had started hazing over the print before it stopped. Don’t know if this might be related?
    Many thanks
    Sharon.
    Jason Bagladi replied 12 years, 7 months ago 2 Members · 2 Replies
  • Graeme Dingwall
    1 June 2013 at 12:07
    Hi Sharon,
    The fuses are on the main board which is on the back right hand side of the printer,
    They are solder on fuses located on the bottom right of the main board.
    Graeme
  • Jason Bagladi
    1 June 2013 at 13:12
    I had a similar problem when I had a Cadet. Fuses had blown, and as stated they are soldered to the main board. I got some separate inline fuse holders and soldered them in place of the board mounted ones. Maplin should have these along with the correct fuses.
