Home Forums Vinyl Cutter Discussions Mimaki Cutters Unfinished cuts on Mimaki CG-fxii
  • Unfinished cuts on Mimaki CG-fxii
    Posted by Lorraine Clinch on 21 February 2016 at 14:45
    Hi all
    Problems yet again (big sigh 🙄 ) with the Mimaki CGfxii.
    It was cutting beautifully, and now it isn’t.
    For some reason it is stopping cutting before the corner on every straight cut. Rounds are fine, and cut completely . Also the starting edge (corner) is lifted, again only on straight cuts. I am pulling my hair out, having spent about three hours with the manual in my hand, chasing between the PC and the cutter settings.
    I don’t have anyone locally who I can bounce off, so I am hoping that one of you good people can set me on the right road!
    Thanks in advance
    Lorraine
    Stafford Cox replied 9 years, 10 months ago 4 Members · 6 Replies
  • John Thomson
    21 February 2016 at 15:58
    blade offset and overcut settings?
    Blade offest is normally 0.25mm and your overcut 0.50mm ( although experiment for your best setting)
    hope that helps.
    john
  • Lorraine Clinch
    21 February 2016 at 16:15
    Hi John, thanks for your reply. I have worked my way through the settings for both. The overcut worked in part, but I still have a large uncut area on each side (i.e. the ‘square cut’ test cuts 2/3reds but not the final 1/3). Weird.
    Lorraine
    21 February 2016 at 17:11
    Are you sure the blade hasn’t chipped or blunted? If it was cutting oK before but now it isn’t, and you hadn’t changed any settings – then it must be the blade?
  • Lorraine Clinch
    21 February 2016 at 17:57
    Hi Phil, I’ve tried one of the Edward Mathias blades too, still the same result.
    Lorraine
    21 February 2016 at 18:00
    Are you using a different vinyl to normal (i.e thicker or laminated)?
  • Stafford Cox
    22 February 2016 at 09:56
    Hi Lorraine. How does the cutting strip look? If you send the job right justified, does it improve?
    Stafford
