Home Forums Sign Making Discussions Neon, LED, Lighting Trying to source Light box extrusion please?
  • Trying to source Light box extrusion please?
    Posted by Graham Shand on 2 June 2012 at 08:51
    Hi there, can some kind person remind me of who can supply aluminium trim to fabricate a double sided light box, I am sure I have seen it linked to the tool bar but for the life of me cannot seem to locate it, cheers in advance
    Graham Shand replied 13 years, 6 months ago 3 Members · 6 Replies
    2 June 2012 at 12:10
    Universal will do the extrusions mate…
    which reminds me i need to contact them regarding flex-face extrusion.
    http://www.universal-aluminium.co.uk/
  • Graham Shand
    2 June 2012 at 12:20
    Cheers Rob appreciated
    2 June 2012 at 12:41
    depending on your chop saw you will use for mitres, remember some extrusion’s might not fit in the throat of your saw. just mentioning as i remember many years ago before slimline extrusions and the like came about we bought a pile of the stuff in to do our own boxes and our chop saw throat would take the extrusion. 😕 :lol1:
  • Graham Shand
    2 June 2012 at 13:45
    Very good point, I use a couple but will check the clearances before ordering, will probably try a get a few off cut samples. Thanks again
    2 June 2012 at 15:11
    If you have a compound mitre saw then there shouldn’t be to much of a problem Graham, I’ve got a relatively cheap one but it cuts up to about 320mm think the blade cost about half what the saw cost lol
    Bit of fiddleing about to get it to cut a true 45 degree angle over a longer length but once set up no problems at all.
  • Graham Shand
    2 June 2012 at 17:41
    Martin, I have had issues in past with finding the real 45 degree angle on the larger hop saws, but as as you say once set up, I have made a template 45 degree set square, but it can drift on occasions.
    Graham
