Home Forums Sign Making Discussions CNC Router and Engraving Trying to source an engraving tutorial DVD?
  • Trying to source an engraving tutorial DVD?
    Posted by Simon.James on 14 July 2009 at 22:37
    Hi Guys
    Does anyone know if there is an engraving tutorial dvd on the market. tried Master engrave but they said no.
    I have bought 2 old roland 2300 engravers working like a dream, tried out loads of plastics through, but i am itching to do some infill on brass & stainless.
    does anyone know of a dvd out there to show me how to infill with paints etc. ????
    kind regards
    simon
    MOD-EDIT :police3:
    Please use descriptive topic titles when posting.
    Please use the relevant forum when posting.
    This post has now been edited and moved.
    PeterKettle replied 16 years, 5 months ago 4 Members · 5 Replies
  • Stephen Henderson
    15 July 2009 at 10:11
    Hello Simon, When i do paint infills on brass I use a syringe filled with the paint. Just before it is dry I wipe of as much over-spill as poss, and then when dry buff and polish. Some of the plastics I use I have had problems with so I tend to stay away from porous ones and only fill ones that can be filled from the rear. You should not need a DVD for this mate, a bit of practice will see you right.
  • Graeme Harrold
    15 July 2009 at 10:22
    Have a look at Mastergrave, they have some stuff plus the Engravers Bible
    I do quite a bit now, and as Steve says, get yer hands dirty and just give it a go. Caution on Stainless as you will need a cutting fluid, brass is a self lubricating metal and engraves a dream. If you are using a nose cone to limit the depth, remove the protective plastic and flood with std vinyl. It tends to stay on better and acts as a very good paint mask. :lol1:
  • Michael Egan
    15 July 2009 at 14:23
    Have a look here http://www.shoerepairer.info/index.php?pid=14
    Scroll down to engraving and there is a couple of tutorials.
    😉 hope this helps 😉
  • Michael Egan
    15 July 2009 at 14:33
    I would probably give stainless steel a miss. Only a few of the larger, new machines will handle this without knackering the machine.
    Brass shouldn’t be a problem.
    I leave the protective coating on the brass and add a layer of cheap, thin vinyl.Keeps the brass nice.
    You should cut to 0.3mm on brass.With small lettering and logos just pour on cellulose and use a spreader to get right into the lettering,leave to dry and clean with thinners then polish.
    For larger lettering I use Gravographs’ Gravolaque paint with a syringe.This flows much better than cellulose paint without thinning.This way, if done properly shouldn’t need hardly any or hopefully no cleaning up whatsoever.
    Polish over with Peek metal polish and jobs a good’un 😎
  • PeterKettle
    27 July 2009 at 16:40
    Hi Simon
    Using vinyl as a paint mask is a good tip. If you do decide to engrave without the nose cone on the PNC2300, cut only 0.1mm per pass at around 10mm/s, to a total depth of 0.3mm. Then try the colour filling technique in the attached pdf.
