Home Forums Vinyl Cutter Discussions Roland Cutters trying to set up my vesacamm through a network hub
  • trying to set up my vesacamm through a network hub
    Posted by George Elsmore on 13 March 2010 at 08:45
    Hi All, can anyone talk me through how i can set my vesacamm up through a network hub i am struggling, i can plug the versacamm up straight to the ethernet card and it works fine as soon as i try through a hub it will not connect
    heeeelllpp
    ta G
    George Elsmore replied 15 years, 9 months ago 4 Members · 13 Replies
  • 13 Replies
    13 March 2010 at 10:09
    quick guess george is the firewall
  • Frank Horner
    13 March 2010 at 10:13
    If you are connected direct and working ok you must be using a crossover cable, and to work through a hub you need the std network cables.
    Frank
    13 March 2010 at 10:18
    some switches are auto sensing and cross over cables work…. (hubs is an old device from the 90’s :wink:)
    On a normal set of wires George, plug in and a light will appear on the switch and the computer socket, this means ‘connection’… then thats it.
  • George Elsmore
    13 March 2010 at 10:33
    quote Chris Wool:
    turned off firewall and still not connecting
  • George Elsmore
    13 March 2010 at 10:34
    quote Dave Rowland:
    plugged in light on but versa works says not connected
    13 March 2010 at 10:59
    George… do you have Lights?! oh u said
    Ok, IP numbers then, but then again it cant be.
    So if a cross over works, then you put a ‘switch’ in the middle of it all and then plug in and it doesn’t work.. hmm but lights are on.
    Where is your internet signal coming from ? this same switch/hub?
    13 March 2010 at 11:08
    Like this
  • George Elsmore
    13 March 2010 at 11:28
    Dave it is set up as the bottom diagram but versa works says that the printer is not connected???
    13 March 2010 at 12:42
    my experience is you can’t have the printer on the same hub as the internet.
    as the internet hub wants it on automatic selection. knocking the printer out.
    my internet hub is connected by usb.
    4 printers and 5 computers through a separate hub with set ips.
    but that leaves me with internet on only one computer.
    13 March 2010 at 15:29
    hm.. i have all network data connected into 24 port gigabit switch, its non-managed too and doesn’t miss a beat.
    There is this belief of running a printer on an isolated switch, i guess its for support reasons as you isolate it out.
    George, you gonna have to write some makes / model numbers down now, so we can see if that switch has got DHCP enabled and is conflicting with your router. If you got it setup as the bottom drawing, then that perfect.
  • George Elsmore
    14 March 2010 at 08:43
    Dave, the switch is a netgear 5-port 10/100 fast ethernet switch and the router is a gigaset se572 wlan dsl if that helps
    14 March 2010 at 09:38
    well i have one of these switches under my desk, nothing special about them and can be used the way you describe.
    If Netgear is the white one, you should have 3 numbers lit (1 for PC, 1 for router, 1 for printer)
    If its the blue one then you should see 3 lights above each cable.
    Normally the lights flash occasionally for network traffic and can flash together.
    The router gigaset (orange by any chance?) controls the network, it gives out a signal (called DHCP) to the printer and the computer to tell it whos boss, it will tell the computer to become a certain IP number, however if the printer is set to ‘fixed IP’ which they are normally it will become invisible to the PC if the numbers are not similar to each number.
    IF all lights are working on router then…
    In the TCPIP settings is something called IP number on the printer…
    write this down… i take a guess at 192.168.0.42 for the printer.
    On the start up CMD (command prompt) and type the command IPCONFIG
    this will list out your IP number… make a note. I am expecting this to be similar to 192.168.0.2 or some number that is non-sense.
    BUT
    If your still getting this for local area connection
    Then I am going to blame a cable!!! find another and try between switch and PC and make that link work
  • George Elsmore
    14 March 2010 at 10:29
    Dave you pointed me in the right direction it was all to do with different ip addresses for the printer versa works and the computer now they are sorted cheers 🙂 iou a beer
