Home Forums Software Discussions Flexi Sign Software Trouble exporting a large file in pdf to send to a printer
  • Trouble exporting a large file in pdf to send to a printer
    Posted by Jonathan Wallace on 8 April 2011 at 13:39
    I am having trouble exporting a file from Flexi in a PDF format for emailing to a printer. It seems to be selecting the image but also a large area of the page that has nothing on it. I then get a message saying@The PDF page size has exceeded its limit. Do you want to scale the document. I hit OK. Then ‘Error generating PDF File. Any help would be appreciated.
    Jon Marshall replied 14 years, 9 months ago 3 Members · 3 Replies
  • John Harding
    8 April 2011 at 13:57
    maybe there is something else you cant see ie white on white
    try grouping your image first
    then ctrl A (selects All)
    hold the shift key and click your image (now the extra bit you dont wont will be the only bit selected)
    hit delete
    resave file and try again
  • Andrew Martin
    8 April 2011 at 14:03
    I’m not familiar with Flexi, but on some programs if your design is in the middle of a A4 sheet on the screen then you export to PDF then the whole A4 will be part of your file hence lots of white area.
  • Jon Marshall
    8 April 2011 at 20:23
    Yes flexi does that. Make the page size smaller than the image you want to print. I think it does have a size limit as well. You could scale it up on the rip instead.
