Home Forums Sign Making Discussions Vinyl translucent or 751
  • translucent or 751
    Posted by James Martin on 12 February 2009 at 12:04
    Can anyone tell me what the difference would be lettering the outside of windows between translucent vinyl and a cast film.
    The inside will be flood coated with etched or dusted (the customer is making up there mind on that one).
    Will the effect differ greatly.
    I tend to use 751 for just about everything I can (not banners) just to cut down storage space, but if I thought the translucent would be alot better I would get it in.
    Its mostly a red circle logo with black letters surrounding.
    James Martin replied 16 years, 9 months ago 2 Members · 4 Replies
  • Martin Cole
    12 February 2009 at 12:42
    quote James Martin:
    I would say not.
    Unless you have a light shining direct onto window from inside but this will be diffused by the frosting.
    Only difference is translucent has a sort of matt/silk finish,
    what sort of effect are you after, or think might be achieved with translucent James?
  • James Martin
    12 February 2009 at 13:01
    Its for an interior designers Martin.
    So she will have a good eye and It just occurred to me that it might make a noticeable difference, just as readable from the outside but softer from the inside with the day light coming through
    Wont be any strong lights on them directly from either direction.
  • Martin Cole
    12 February 2009 at 13:37
    quote James Martin:
    Ah, see where your coming from James.
    Just done a test on my window and the translucent does give a softer
    finish, so may well be the way to go.
    Try it if you have a piece.
  • James Martin
    12 February 2009 at 15:09
    Dont have a piece to try for myself Martin but cheers.
    I will ask her if she wants to see the diff, and i will get some for her just to make things more complicated.
    She’s up to high doe moving premises, was with her for 20 mins the other day and she had 3 cups of coffee, (thought she was gonna run up the curtains before I left).
