Home › Forums › Sign Making Discussions › Vinyl › To fit wet or dry?
To fit wet or dry?
Posted by Neil Beckett on 8 December 2012 at 09:38Hi all,
I’m soon to install the following 3 elements to a Pizza house – see photoshop visual – ( window frosting, opening hours and a finest pizza graphic. These will all be fitted internally looking out.
This will be my fist attempt at frosting. In your opinion should they all be fitted wet? Any tips for the frosting?
Many thanks,
Neil.Neil Beckett replied 12 years, 11 months ago 7 Members · 12 Replies -
quote Neil Beckett:Hi all,
Many thanks,
Neil.If that was me i’d fit all the etch wet with Rapid Tac (or similar) and all the rest dry, do the etch first and by time you’ve finished the rest you’ll be able to remove the app tape from the etch.
Just me though :lol1:
Or use air release file and fit the etch dry. Used it the other day and although more expensive saves on application fluid and wiping the windows down afterwards.
Alan D -
Personally I would fit it dry but realistically your best bet would be to fit using what ever method you are confident with, having confidence as far as I am concerned is more important than anything else.
Rather than wait until the day why don’t you cut some graphics & experiment either at home or at your unit. At this stage you need to keep practicing anyway if you want to become proficient. All part of the learning curve. -
For the #1s I would probably use Rapid Tac 2.
The other stuff do dry.
Or…do the dry stuff first and then when you get a feel for it do the #1s last.
Maybe cut extra of those just in case.
Love….Jill -
Done a small job like this lately,it also was my first time using this type of material.i decided to try it dry and it turned out fine,i did take extra graphics & App fluid with me in case i was struggling when i was on site.
Thanks for the feedback.
My only concern with the window etch doing wet is the words Pizza House which sit within a cut out rectangle. I’m concerned these may move if done wet?
Client has already chosen a MetamarkM4 -OF Frost Monometric Calendered film. I may see if she will change to Polymetric film as I don’t want the job to shrink after Ive done it.
thanks.
Try doing the pizza house bits dry after you fit the other parts?
I always use Oracal 8510 series and have never ever had a problem, wet or dry. -
when you get your the job done you might let us know how it went for you,maybe post a photo.
cheers, john 🙂
I would go dry and as others have mentioned it depends which way you feel confident.
quote Neil Beckett:Thanks for the feedback.
thanks.
Not quite sure I follow you here Neil, did the customer come to you already with a material spec if they have chosen a particular vinyl??
Personally don’t touch monomeric so if a customer approached me asking for a particular vinyl I would point out the reasons I wouldn’t use it before taking on any work, if they were insistent then fair enough but I wouldn’t try & talk them round at this stage once visuals had been done. -
Hi Martin,
No, I just blindly gave them the Metamark etch brochure to choose from and admit at the time I didn’t understand the difference. Theres only one (first one in the brochure) which is Monometric and the customer chose this one. Fortunately out of curiosity (as this was the only Monometric) in the brochure, I thought I’d better find out what the difference was and googled it which ironically brought me back to a thread on this site and made me realise the error of my ways. Still learning 🙄
I will see the client later this week and advise them to chose one of the Polymetric films. I agree after reading a thread on this subject I can’t really see why anyone would want to use a Monometric unless it was for a very short term use and wanted to be done as cheap as possible.
thanks.
