Home Forums Sign Making Discussions General Sign Topics Tips & tricks for printed vinyl on both side of an acrylic!
  • Tips & tricks for printed vinyl on both side of an acrylic!
    Posted by Erdy Cem on 20 January 2022 at 15:53
    Hi Guys,
    In order to get a vibrant and nice print quality on a lightbox sign, some people sticks vinyl prints on both side of an acrylic (one being printed reverse).
    Is there any tips and tricks for backlit vinyls applied on both sides of a perspex for a precise alignment? How do you position them perfectly without any slipping?
    Ta.
    David McDonald replied 3 years, 10 months ago 6 Members · 9 Replies
  • 9 Replies
  • David Wilde
    20 January 2022 at 16:09
    Never heard of this before? Be interested to see how many on here have use this method.
    We’ve never really had an issue with vibrancy though, we use Opal Perspex and Translucent back-lit vinyl printed on the correct profile for the vinyl (which usually is the highest quality/longest print time).
    Have to say I’d be concerned about doing a double layer though.
    • Erdy Cem
      20 January 2022 at 16:49
      I was advised by another sign guy some time ago..
      Reason being, I’m never happy with the print on backlit vinyl when it’s illuminated. We’ve got HP latex, and we print on a proper backlit vinyl with correct profile on opal perspex.
      but once it’s lit, it looks faded, not enough vibrant.
      So I thought if we could do double print then it can be better.. But I don’t know if it’s possible without having it double layer..
  • Joe Killeen
    20 January 2022 at 16:50
    In over 35 years making and fitting signs I have never seen a lightbox panel finished on both sides, clear panel with reverse side image or opal with forward image.
    Try printing onto clear vinyl and mounting to opal.
    Why do both sides? twice the work and extra material cost.
    • Erdy Cem
      20 January 2022 at 17:06
      Thanks Joe..
      We jumped into digital printing a few years ago from making channel letters only.. We’ve got long way to learn about printing..
      Don’t you think clear vinyl will be worse than backlit vinyl on illuminated opal?
  • David McDonald
    20 January 2022 at 17:51
    Hi Erdy
    We’ve done this once and it wasn’t a huge improvement – we included reg marks to align to the 4 corners of the Opal acrylic so was very simple to get registration both sides. We just created a high pass, high saturation profile and it works well HP560 with Metamark MDT600. I suppose it depends on the design but we’ve been happy and customers have been happy staying single sided since
    • Erdy Cem
      20 January 2022 at 22:15
      Thanks David.. I used Metamark MDT600 too with supplied profile. Do you mean that you edited the profile to do high pass and more inks?
      I’ll try that.
    20 January 2022 at 21:45
    As David said, if we were to do that, we’d use crop or regmarks and align it to a precut sheet.
    But why?
    Opal acrylic will diffuse the light. Double pass on clear works, we’ve done that save buying in a roll of translucent film for what bits we do. All the RIPs we’ve used have had a clear profile.
    If I was doing this kind of work regularly, translucent vinyl, and print normally.
  • Jamie Wood
    21 January 2022 at 08:41
    As David says, you need to double strike the ink on backlit, to get the vibrancy when lit.
  • David McDonald
    22 January 2022 at 09:40
    Hi Erdy
    Off hand I can’t remember the exact settings, possibly 12-pass with 170 / 180 ink and highest curing temp.
    It’s looks better on the MDT600 than on clear
