Home Forums Sign Making Discussions Vehicle Wrapping Tips for Motox laminate cutting by hand as cutter will not?
  • Tips for Motox laminate cutting by hand as cutter will not?
    Posted by Lee Atkinson on 13 January 2015 at 18:43
    Hi Folks, I’m having a bit of trouble on the cutting thick laminate situaation.
    I have a tjet 1631c and printing the decals, putting on a heavy laminate. Putting the cutting blabe to 10v (max) the machine doesnt allow numerous cuts but it just isn’t cutting it.
    I then decided to take it over to my liyx sc631c with optical eye, screwed the pressure up full again and still nothing. If u push hard enough, it will come off but quality isn’t there.
    Has anyone any suggestions on softer motox laminate or suitable laminate or…….. try cutting them out by hand?
    Thanks folks for any suggestioons no matter how small,
    Robert Lambie replied 10 years, 10 months ago 1 Member · 1 Reply
  • 1 Reply
    15 January 2015 at 12:01
    quote Lee Atkinson:
    Putting the cutting blade to 10v (max) the machine does not allow numerous cuts
    What about…
    Cut as normal. when its finished, click cut again?
    It will just cut the exact same thing again over the same cut path.
    Note: Make sure you cutter is set at "return to origin point" – Beginning.
