Home Forums Printing Discussions Roland Printers Tiling and cutting in Versaworks
  • Tiling and cutting in Versaworks
    Posted by Emyr Evans on 14 October 2016 at 13:52
    I need to print some vinyl wall graphics which I’ll need to tile in Versaworks. Is there any way I can do a print, laminate and cut using the tiling function?
    Emyr
    Joe Wigzell replied 9 years, 2 months ago 2 Members · 3 Replies
  • Joe Wigzell
    17 October 2016 at 10:32
    Hiya,
    If you require crop marks on each tile, set up your job as normal using hte clip and tile, then use the custom cut feature (set a page length) to split the job. Each section will then have it’s own crop marks.
    Hope that helps?
  • Emyr Evans
    20 October 2016 at 15:47
    Hi Joe
    Would this just give me marks to align a ruler on? What I’d like to do is print, then laminate and put it back into the printer for cutting – don’t know if this is possible with tiling.
    Emyr
  • Joe Wigzell
    21 October 2016 at 09:16
    You could also add trim/margin marks using the marks tab of VersaWorks if you like (for ruler trimming).
    But as you said, if you want to print, lam and cut that’s exactly the process mentioned previously!
    Definitely possible with tiling, just have to use the custom cut feature.
