Home Forums Sign Making Discussions General Sign Topics Those wire things
  • Those wire things
    Posted by Dave Bruce on 4 February 2004 at 17:18
    Can anyone give me a contact for those lovely wire thingy ma jigs that you see in estate agents windows etc. They hold pictures of property with some nicely machined aluminium button things holding on to the wire. 😳
    Does anyone understand me? 😕
    Dave Bruce replied 21 years, 10 months ago 8 Members · 14 Replies
  • 14 Replies
    4 February 2004 at 17:22
    shop kit do it. http://www.shopkit.com
    01923 818282
    4 February 2004 at 17:25
  • Dave Bruce
    4 February 2004 at 17:32
    cheers Rob i’ll be on to them 2moro.
  • -steve
    4 February 2004 at 20:54
    i think this mob are a b it cheaper than shopkit:
    http://www.hobday.co.uk/8display.asp?prodname=SFittings
    steve
    4 February 2004 at 22:12
  • Dave Bruce
    4 February 2004 at 23:01
    Thanks Steve and Nik, yer they look a bit cheaper.
  • Nigel Hindley
    5 February 2004 at 00:08
    Like Nik I deal with Fairfield they are very helpful
    Nigel
  • Andy Gorman
    5 February 2004 at 00:22
    On a similar topic, has anyone used something like this….
    http://www.fairfielddisplays.co.uk/designguide/products/signsystems/signsupports.htm
    I’ve got to mount 96″ x 22″ clear acrylic panel ‘stand off’ and I wondered if these were up to the job. With the high winds at the moment I’m a bit concerned with safety.
    Any suggestions?
    5 February 2004 at 00:30
    yeh no worries mate. they are basicaly the part that holds the perspex/glass you put a normal screw about 2″ through that into rawl plug, into wall. holds great.. cost a few quid each, but look the part. 😉
    ive saw alternatives used. basicaly, if you want to do it right, use these.
    the alternatives normaly look cheap & unprofessional. 😕
    im hoping to have a very new type of signage demo loaded for tommorow night late on. im actualy using these type of locators at the end of it..
    watch this space 😉
    oh yeh, you will probably need 8 of them to hold it properly, 6 would do, but safer with 8. 🙄
  • Andy Gorman
    5 February 2004 at 00:37
    Thanks Rob. The only thing that concerns me is the bit that screws in through the face of the sign. Is there a method that will minimise the chances of these rattling loose over time? Bearing in mind that the sign in question will be 75mm away from the wall – plenty of room for the wind to get behind and cause all sorts of stress on the fixings.
  • Nigel Fraser
    5 February 2004 at 19:21
    Don’t know if you will find any which are as long as 75mm unless you can get Fairfield to do some specials?
    I use a lot of these (normally get them from Hobday see link above, or sign metals and plastics 0121 555 7747) and I put a dab of silicone sealant on the thread before fixing. It holds it safe and means you can undo it when required.
    Nigel
  • Andy Gorman
    5 February 2004 at 21:12
    One of the links above do one at 75mm, in fact I think it was Fairfield.
    Good idea with the silicone sealant, I was thinking of Loctite but I was concerned in case I ever have to remove it. That stuff is difficult to loosen without a spanner.
  • Richard
    13 February 2004 at 06:20
    Another manufacturer of this type of product is http://www.albion-manufacturing.com/default.asp
    Very good quality product.
    I couldn’t remember the name of the company when this thread was current as the company I’ve worked at for the past six years is not involved display installtions at all.
  • Dave Bruce
    13 February 2004 at 10:12
    Thanks Richard, another good contact for me, had the edge lit signs I have been looking for too.
