Home Forums Sign Making Discussions Vinyl Thicker than normal vinyl?
  • Thicker than normal vinyl?
    Posted by Chaz Virdee on 20 May 2009 at 11:32
    Had a request from a friend to make up some stencils that will be used to sandblast a logo onto some glass. I’m pretty sure the usual 70-75um stuff won’t hold up during the process. Is there anywhere I can source a thicker more durable vinyl for said application.
    Cheers Chaz
    Chaz Virdee replied 16 years, 6 months ago 5 Members · 5 Replies
  • Jason Xuereb
    20 May 2009 at 11:45
    Pretty sure you can get sand blast material you cut with a 60 degree blade.
  • Kevin Flowers
    Chaz
    most vinyl stockist will stock a sandblast film, but they are thick & are better suited to a Tangential Plotter.
  • Dan Osterbery
    20 May 2009 at 12:08
    we buy ours form grafityp over here, and it is specific for sand blasting! It works really well, but do a cut test first it is thick!! we cut it at 185grm
    regards
    Dan
  • Ian Muir
    20 May 2009 at 12:50
    Aslan do sandblast in 3 thicknesses, you only need thinnest for glass but strangely the thickest cuts best on a plotter (very good in fact), set speed low with a 60o blade and you’re away…..
    Ian :lol1:
  • Chaz Virdee
    20 May 2009 at 14:12
    Thanks for the replies guys. I’ve ordered some Aslan S68 medium weight from MDP.
    I’ll let you know how I get on.
