Home Forums Printing Discussions General Printing Topics Thermal reflective problem
  • Thermal reflective problem
    Posted by JOHN.BOLT on 28 June 2006 at 20:10
    Hi been trying to cut out 12point letters on thermal reflective problem has been to get a clean cut on my Roland camm 1ooo, tried different angle blades 60 degrees and 45 but still not clean enough any suggestion would be help full.
    JOHN.BOLT replied 19 years, 4 months ago 2 Members · 2 Replies
    7 July 2006 at 01:42
    have you checked your nylon strip below the vinyl isnt worn…
    also… are you sure your blade is spinning free in the holder? they can clog up over time causing it stick while spinning/changing direction. leaving a dragging effect on the vinyl as oppossed to a clean cut.
  • JOHN.BOLT
    7 July 2006 at 17:12
    Thank you for your response
    Do the nylon need replacing as it does seem to happen, where can I get replacement for it
