Home Forums Software Discussions Corel Software Text to path.
  • Text to path.
    Posted by Alan Bell on 24 November 2008 at 19:02
    Anyone help me with fitting text to path on a circle,
    I can sort out the top arc but not the bottom.
    What am i not doing.
    Thanks in advance
    Ian Muir replied 16 years, 12 months ago 7 Members · 18 Replies
  • 18 Replies
  • Graeme Harrold
    24 November 2008 at 20:00
    Look at the toolbar for all the options like "position", "above, below or on the line" "offset from the line" etc, failing that select node edit and move the big diamond along the line.
  • Ian Muir
    24 November 2008 at 20:11
    As Graeme says play around in the ‘fit text to path’ box.
    Depends if you want it right way up or upside down…. inside path or outside.
    On some versions of Corel it’s not easy to understand or remember, on some there is a ticky box that alters things around.
    Good luck
    Ian :lol1:
    24 November 2008 at 20:20
    ok, draw your circle, then what i do is to draw a line across the centre of the circle, then curve it to the top ark of the circle.
    then do it again, but curve to the bottom half of the circle.
    remove (not delete) circle
    write the text you want on the top and then fit to path.
    write text you want on bottom and again, fit to path.
    once text is i position you can delete the lines (can be handy to make copies of them before adding text though!) and place text around the circle.
    the other thing to bear in mind, if you draw your line from left to right, the text will fit left to right. if you do the opposite and draw right to left, that is how the text will fit, so if you flip a line, the text will also flip when you attach it.
    something to remember!
  • Adrian Yeo
    25 November 2008 at 07:17
    quote Hugh Potter:
    :you: That explains a lot!! 😀
    How many hours have I wasted wondering what I’ve done wrong!! 😳
  • Earl Smith
    25 November 2008 at 09:53
    A similar problem. How do I make my text line up vertically? One letter on top of the other so I can read it downwards.
    Earl
  • Ian Muir
    25 November 2008 at 10:14
    Just put each letter on a different line, i.e. hit return key after each letter…… you can use alignment here, left right, centre.
    You can then adjust spacing/kerning with pick tool.
    Ian :lol1:
  • Earl Smith
    25 November 2008 at 11:20
    Thanks Ian, being doing that. Just hoped there was a fit to path option I could use.
    Earl.
    25 November 2008 at 11:33
    quote Adrian Yeo:
    quote Hugh Potter:
    you and me both!!
    can still be a pain to manually adjust individual letters that don’t seem to tow the line particularly well!
    as for stacking letters, tricky, yup.
  • Steve Underhill
    25 November 2008 at 14:23
    In Corel its very easy and simple to line up letters or use them on a curve, or type vertically
    USE ILLUSTRATOR!!! :rofl:
    I use both, I just wish they could incorporate both of them into one program
  • Ian Muir
    25 November 2008 at 15:33
    Along similar thoughts, I have long wondered why Coreldraw (or Illustrator) didn’t have output to plotter facilities same as Signlab, so you wouldn’t need signlab at average levels at all.. Or maybe answer is that Corel has business links with one of the big sign software providers and knows they can keep the price up there.
    Ian :lol1:
  • Adrian Yeo
    25 November 2008 at 15:38
    Before getting the Cadet, I always cut direct from Coral. Initially using version 8.
    I did get a copy of signpal with my Puma but found it far more awkward to use so stuck with what I was comfortable with.
    25 November 2008 at 15:39
    quote :
    what do you mean Ian and what make plotter do you run
  • Steve Underhill
    25 November 2008 at 15:42
    I cut directly from Corel and use no plug ins at all
  • Earl Smith
    25 November 2008 at 15:59
    I cut direct from Corel too V12. No plug in. But its fun when its a multipage document and I forget to click the print current page box.
    Earl
  • Ian Muir
    25 November 2008 at 16:02
    I’ve always used Rolands except I once had a Mimaki running along side my Roland at the time.
    To explain what I mean let’s imagine a fairly basic vector to cut, say 3 meters x 1 meter, 3 colours of vinyl, one of the colours at end of the drawing.
    If, as I do, I export as eps to signlab I select one colour with one finger and select cut, it cuts from start of vinyl. Select another colour it cuts etc.
    In corel as far as I understand you first set up a page (which has limited maximum dimensions), then you have to manually drag your chosen colours (how do you select all of one colour with one finger press) down to beginning of your page, making sure your within the page or you miss some, destroying your drawing in the process and then cut. Alternative is to put all of your drawing on the page but what if one of your colours is only at end of the drawing, you still have to drag that to beginning of page.
    Or perhaps you guys know a better way, hope so…..
    Ian :lol1:
  • Earl Smith
    25 November 2008 at 16:12
    What I do is make a full copy of the design on page one in Corel, in your case all 3 colours. Then I select one of the colours by selecting each piece of the same colour. ( as far as I know its not possible to select all the same colour with one click). Copy those selected and paste them to a second page. Do the same with the other two colours , each to their own page. What you must do is GROUP all the items of each colour, on and off the page or the cutter will only see what is on the Corel page. Then go to print/cut and select each page as you load your material. etc etc
    Clear as mud.
    Earl.
    25 November 2008 at 16:31
    quote Ian Muir:
    Ian :lol1:
    you are obviously well sorted so whats your problem 😀
  • Ian Muir
    25 November 2008 at 17:44
    No problem Chris, just responding to another members observation……. would be more efficient though if cutting could be handled better in Corel only.
    The way I do it does lead to Corel, EPS and signlab files all for one job which is not so brilliant…. and, especially if I’m busy, I sometimes notice that I need to tweak a design, say a node or kerning in signlab as I’m about to cut rather than re-adjust in Corel and re-export… that can be a nuisance if I ever have to repeat a version of that job at a later date.
    Ian :lol1:
