Home Forums Software Discussions Corel Software TEXT ANGLE OF ROTATION IN COREL X3
  • TEXT ANGLE OF ROTATION IN COREL X3
    Posted by George Elsmore on 19 February 2009 at 11:08
    Morning All, something weird has happened in my coreldraw, if i type some text the angle of rotation has changed to 270 degrees by default??? how do i set it back to 0 degrees please.
    Thanks in anticipation Mr Drury
    Alan Drury replied 16 years, 9 months ago 3 Members · 5 Replies
    19 February 2009 at 11:11
    Time to get out of bed George, might look fine then.
    Actually George, without doing a Reset, I have no idea… Mr Drury, over to you.
    19 February 2009 at 11:32
    Personally I wouldn’t mess a bout, save workspace if customised, restart draw with F8 and accept factory defaults – reload workspace and carry on.
    F8 is your friend, anything going on a bit strange use F8 🙂
    Alan D
  • George Elsmore
    19 February 2009 at 11:34
    Will do Alan many thanks
  • George Elsmore
    19 February 2009 at 11:36
    Just a thought Alan will F8 knock out any settings i have ie cocut and such like?
    19 February 2009 at 11:42
    I don’t run CoCut so I can’t give a definitive answer, I do run Summa’s Winplot which has icons on the toolbar, using these basically runs Winplot and transfers the objects into it automatically for step and repeat and cutting. Providing the workspace with these icons has been saved everything is ok.
    F8 loads the factory default workspace as it was on install, reload your workspace and everything is back but you will need to reload any custom pallette and the hotkeys for macros won’t work.
    If CoCut works in this way it should be alright. (cross everything you have 2 of 🙂
    Alan D
