Home Forums Sign Making Discussions Neon, LED, Lighting Test Certificate for illuminated sign
  • Test Certificate for illuminated sign
    Posted by KerryE on 30 March 2010 at 12:16
    We are supplying a simple box sign with standard tubes/electronic control gear.
    The contractor on site has asked for ‘test certificate’ to be supplied
    What does this mean?
    Does anyone know what legally needs to be supplied?
    I hasten to add that we are not making this ourselves but buying off a fairly big supplier, but I cant seem to get an answer so far.
    many thanks
    Jason Bagladi replied 15 years, 8 months ago 4 Members · 6 Replies
  • Neil Davey
    30 March 2010 at 18:51
    By the look of your website I would have thought you’d know what to do.
    Haven’t you got an electrician in your company 😉
    Hopefully Graeme will see the post, he’s our UKsignboards spark. 😀
  • KerryE
    31 March 2010 at 08:56
    No electrician in house sadly.
    All these electrical regulations are rather stringent these days so I was just trying to find out what legally we had to do to comply.
  • Chris Windebank
    31 March 2010 at 10:30
    get the supplier to issue the certificate
  • Jason Bagladi
    31 March 2010 at 11:10
    The sign box should be CE marked and issued with a declaration of conformity from your supplier.
  • KerryE
    31 March 2010 at 12:26
    Many thanks for the replies but…
    a) what are they actually required by law to test?
    – to see if the tubes work?
    – to ensure the wires are OK?
    b) ‘Certificate of conformity’
    – does this need to mention conforming to certain regulations?
  • Jason Bagladi
    31 March 2010 at 13:30
    The units should be electrically tested, earth continuity, insulation resistance, PA testeded if it’s a plug in unit etc.
    The declaration of conformity should list the European Directives which were applied in the design, testing of the unit.
    These will probably be:-
    Low Voltage Directive
    EMC Directive
    It can start getting pretty complex for what appears to be a simple unit, but all this should be supplied by the manufacturer.
    You cannot apply a CE mark yourself!!!
    I have worked with Epson in the UK and Japan on CE marking equipment and its a mine field.
    Hope this helps
    Jase
