• temp gauge
    Posted by Nicola McIntosh on 1 October 2006 at 20:29
    hi folks 😀
    im after a laser temp gauge, any ideas where to buy one and how much do they cost 😀 as im away to start wrappin (spin) also if you do use one what do you like or dislike about them 😉
    thanks
    Richard Urquhart replied 19 years, 2 months ago 8 Members · 13 Replies
  • 13 Replies
  • Nick Minall
    1 October 2006 at 20:40
    This sort of thing?
  • Jeremy Howes
    1 October 2006 at 20:48
    Hello Nik,
    I use a Raytek Minitemp which I bought from a supplier in the USA, If I remember correctly it cost around £40 – £50, unfortunately I do not have the suppliers details but I’m sure that they are available through Ebay or the like…..
    These are an essential piece of kit for those of us in Dye Sublimation.
    Good luck with your search
    Jeremy
  • John Childs
    1 October 2006 at 21:14
    Ours came from Cox Plastics with a load of vinyl.
    It works well and does the job.
    Have you done the training course Nik? or are you giving it a go, based on your own experience, and from advice given on the boards and elsewhere?
    Just wondered,
    1 October 2006 at 21:20
    this is the one i use, think i paid about £90
    only a few weeks ago one of our members of staff very kindly dropped it into water for me… 😕 this has just reminded me to buy a new one!
    http://www.raytek-northamerica.com/cat. … t_id=2.3.5
    i think the gun type hand is best with big display.
    watch you dont get one with low temp setting… i.e. max indication of 100 degrees… go for around 200 degrees and above
    1 October 2006 at 21:21
    quote Peter Normington:
    giving it a go peter on my own with help obviously from everything mentioned from the experts on the boards , im a determined so-and-so just itching to get started 😀
    1 October 2006 at 21:24
    Go for it Nik, Sure you will make a good job, are you starting with your own motor? or usng an unsuspecting guinea pig?
    1 October 2006 at 21:29
    thanks peter, im going withour own van 😮 will keep you posted for sure 😀
  • Jim Clough
    2 October 2006 at 07:15
    Dop you have a Maplins nearby? I got one there for £49
    Jim
  • Richard Urquhart
    2 October 2006 at 21:13
    rob as you know is the spec on this one ok
    thanks rich
    TN2 laser guided Infrared Thermometer Ref: 102621
    The TN2 is a non-contact infrared thermometer, possibly the smallest infrared thermometer with laser alignment on the market today, measuring only 18 x 50 x 100mm and weighing just 62 grams.
    Simply aim the thermometer at the target and press the read button to display the surface temperature. The TN2 indicates temperature over the range of -33°C to +220°C with a resolution of 0.1°C.
    The TN2 thermometer incorporates an optical lens that measures temperature by sensing the amount of radiated energy at infrared frequencies. Using this data and the actual temperature of the infrared sensor (thermopile), the TN2 can calculate the temperature of the surface that emitted the energy.
    The distance to target ratio is 3:1 therefore the thermometer should be positioned as close to the target as practical. The TN2 infrared thermometer incorporates maximum, minimum and lock (continuous) functions and is switchable between °C and °F. The unit is supplied with a default emissivity of 0.95, however, the emissivity can be changed from 0.01 to 1.
    Price: £41.42 (Including: VAT at 17.5%)
  • Richard Urquhart
    2 October 2006 at 21:14
    or i should have asked what temp will it need to read up too
    2 October 2006 at 21:16
    quote Richard Urquhart:
    thanks rich
    a bit goobily gooch to me richard…where did you get it from? 😀
  • Richard Urquhart
    2 October 2006 at 21:18
    have a look here
    http://www.thermometersdirect.co.uk/aca … d=Infrared
