Home Forums Sign Making Discussions Vinyl t shirt vinyl bubbled and warped while cutting?
  • t shirt vinyl bubbled and warped while cutting?
    Posted by Martin Parker on 19 November 2007 at 13:24
    hi i have mentioned before i am using the mdp hot flex ultra vinyl for t shirts but i had a strange thing happen last night the vinyl bubbled or warped while cutting but when u ran the vinyl thru it was fine without cutting and also when i cut the same thing on normal vinyl after it it cut fine what id like to know is this defective vinyl
    and can someone recommend some other t shirt vinyl we can try that they have had good experience/results with and a link as to where to get them from
    thanks in advance
    martin
    Nigel Pugh replied 18 years ago 6 Members · 11 Replies
  • 11 Replies
  • Byron Villegas
    19 November 2007 at 14:02
    I order my t-shirt vinyl from forever-ots.com, Germany. So far, I’ve had great results.
  • Nigel Pugh
    19 November 2007 at 14:13
    Can do some samples for you, take a peek at our website and let me know what you want to try.
    Nigel
    Oh pm your number too, I cannot reply to pm’s
  • Martin Parker
    19 November 2007 at 14:25
    hi nigel i cant pm either so my number is 01418879752
  • Nigel Pugh
    19 November 2007 at 16:47
    Samples are in the post Martin.
  • Martin Parker
    19 November 2007 at 17:07
    cheers nigel
  • Neil Speirs
    22 November 2007 at 19:53
    You could also try xpres, I’ve been using them for a couple of years now and never had a problem.
    http://www.xpres.co.uk/consumables/xpre … _materials
    I will also be giving Nigel’s vinyl a try shortly as his prices seem to be a bit better.
  • Steve Underhill
    23 November 2007 at 15:00
    I use xpres, but if you can do £4.75 per metre on flex and ultra/dura Im quite happy to use grafityp, thats for a single metre or full roll by the way.
  • Nigel Pugh
    23 November 2007 at 15:19
    What width do you use Steve?
  • Dave Bruce
    23 November 2007 at 16:54
    Me too Nigel 🙂
  • Steve Underhill
    Sorry was over the other shop didnt see the reply.
    500mm just the regular super flex dura cut, extra flex etc.
    I suppose its the same across the board name wise just changed slightly.
  • Nigel Pugh
    24 November 2007 at 00:37
    Steve I have next week off from the madhouse, if you pm me a contact number or email I will give you some details.
