Home Forums Printing Discussions Roland Printers switching off the Camm?
  • switching off the Camm?
    Posted by David Crocker on 19 April 2008 at 21:44
    Hi all,
    Ive run out of ink on one pot and i cant get anymore until tuesday. The machine is driving me mad with constant beeping!
    is it ok for me to switch the machine off for a few days? I dont want to tape up the cartridge and then re-insert it because the machine does a clean every 6 hours or so whether im there or not and i dont want it sucking an empty cart. This is what caused my problem from the last episode (i think).
    So, is it ok for short term guys?
    Dave.
    Stephen Morriss replied 17 years, 8 months ago 3 Members · 3 Replies
  • Michael Almand
    20 April 2008 at 18:47
    Hey bud I shut it off for 5 days and never had a problem I probably wouldnt go more than that cause you don’t want the heads to dry out if you want to put a little bit of cleaning solution in the capping station so it insures the head won’t dry out.
    hope it helps
  • Ian Bingham
    21 April 2008 at 09:22
    Can you not switch it off during the day and back on again at night to let it clean?
    Ian
  • Stephen Morriss
    21 April 2008 at 10:49
    No problem switching it off for a few days, you may have to do a head clean to clear a few nozzles.
    The older machines don’t have the auto clean cycles like the newer machines so mine can go upto 3 days without a clean of printing.
    It also shouldn’t try to run a cleaning cycle while it knows a cartridge is empty.
