Home Forums Sign Making Discussions Traditional swinging pub sign question
  • swinging pub sign question
    Posted by George Elsmore on 10 May 2012 at 10:04
    Hi All, i have been asked to replace a swinging pub sign that is wooden with a moulded type plastic so no maintenance so need help scourcing a blank can anyone help please.
    ta
    G
    John Morgan replied 13 years, 5 months ago 7 Members · 10 Replies
  • 10 Replies
  • Lorraine Clinch
    10 May 2012 at 10:11
    Hi George,
    what are you looking for?
    Lorraine
  • George Elsmore
    10 May 2012 at 10:33
    Hi Lorraine, thanks for them as i cannot see anything like on there website
  • Lorraine Clinch
    10 May 2012 at 10:51
    Sorry George, not sure from your reply, is this not what you were looking for?
  • George Elsmore
    10 May 2012 at 11:49
    Thanks Lorraine they do not do what i am looking for
    anyone else have any ideas?
  • Warren Beard
    10 May 2012 at 11:53
    Hi George
    Check Jag Sign Supplies, they have plastic framing.
  • NeilRoss
    10 May 2012 at 12:00
    quote George Elsmore:
    Assuming you’re looking for a double sided board, it may still be worth speaking to them. Possibility is that they may be able to stick two back to back to form a single sealed unit.
  • Stuart Miller
    10 May 2012 at 13:08
    I seem to have been doing quite a few swing signs lately and the choices of different qualities I have found are.
    1) 19mm Foam board, either basic or with Jag plastic trim. Iron Signs sells them with the trim already attached as one-offs.
    Not used them as I found it cheaper to buy the 19mm board and make them up myself.
    2) GRP from Sign Master
    3) Aluminium Boards with borders. for a quality board that should last well I can recommend the Aluminiumm ones from Hugo at Sign board Systems, he can makes them with fixing points to suit or he has made one with wooden inserts, that I could then screw directly to an existing frame.
  • George Elsmore
    10 May 2012 at 13:38
    Thanks Stuart 😀
  • Graham Shand
    10 May 2012 at 22:10
    Thank you for the links ! I was just about to go looking, saved me a lot of time
  • John Morgan
    22 June 2012 at 10:31
    Yes excellent Links Stuart !, Ive used some of the companies in the past but Ive Bookmarked your suggestions for future possible use, thanks, John
