Home Forums Sign Making Discussions Vinyl suppliers please of Window Perforated Vinyl?
  • suppliers please of Window Perforated Vinyl?
    Posted by JonnyAnnett on 30 November 2007 at 21:10
    Hi Again,
    Yes I’m asking a lot of question lately. Must be because I’m starting to get work through and take on different challenges and customers?
    Well anyway, had a client call over today. He’s got a new double cab tipper truck. He wants the rear window of the cab used for some advertising hence he came to me for some signage. He gave me a rough idea of what he wanted, so I’ve been left to draw something up.
    Now the major question. He wants me to apply this to the inside of the window, no problem I’ve done that before just reverse/mirror cut the vinyl. But he wants it doing in perforated film, so as he can still see out the window. He wants it in black 😮 , does anyone know if any suppliers carry this I’ve only see White for off the shelf purchasing.
    If not I’ll have to draw something else up and let him have a look at it.
    I’ll post the end result 😉
    Jonny
    JonnyAnnett replied 17 years, 11 months ago 5 Members · 6 Replies
  • Byron Villegas
    30 November 2007 at 22:52
    Some window perf vinyls are already black on the adhesive side. Or you may try the "static cling" materials.
  • Dave Bruce
    1 December 2007 at 13:55
    Jonny, take a look on the boards Rob did a demo of his own window film which I have used on quite a few rear van windows. Basically cut lines of 2mm and leave lines of 3mm, like the one way mirror stuff seen in shops.
  • RobStone
    3 December 2007 at 08:44
    Jonny,
    If you want ‘one-way-vision’ perforated vinyl applied to the inside of windows, you need to use clear perforated vinyl, print your image (in reverse) and then back-up with a layer of white and then a layer of black ink – so that the order when viewed from the outside is image, then white layer, then black layer – the same as externally applied white/black perforated vinyl.
    You can get clear perforated vinyl from a number of suppliers – I know that Europoint have some in stock because I bought a few metres last week.
    Traditionally you would screenprint the white and black layers over the printed clear perforated vinyl – but there is now a simpler way of doing this using a hot-roll laminator. Again Europoint should be able to give you details.
    Applying perforated vinyl to the inside of a window has great advantages – protection from vandalism (or windscreen wipers) and the weather, and not needing scaffolding for high-up windows – but make sure that the glass isn’t heavily tinted or you’ll not be able to see the image!
  • JonnyAnnett
    3 December 2007 at 10:05
    Unfortunately we do not have facilities to print. I’ve looked into print machines but my work to date has not required a printer and I do not feel that at present it would be the ideal investment although possibly in future we will go for one of these print and cut machines. Hence the reason why I was wondering if it was available in other colours.
    After having a think and seeing what I could come up with I spoke with the client again on Saturday and we discussed what he was looking for. We have more or less decided that we will apply the vinyl to the inside of the window and then apply a layer of dark window tinting film over the top of the vinyl which will give the darkened out effect. I am hoping that this method will work and if it doesn’t we may have to resort to plain black vinyl.
    Thanks for all your help once again guys.
    Jonny
    3 December 2007 at 10:20
    quote :
    sorry will look nasty tint the inside lettering out side. arm your self with a scrap piece of glass and try it you will see what i mean
  • JonnyAnnett
    3 December 2007 at 19:30
    quote Chris Wool:
    quote :
    Hi Chris,
    Customer request is all vinyl is inside, so gotta work with him. What do you suggest otherwise?
    Jonny
