I have a job that requires 100 55mm X 28mm polished brass plaques, I plan to print on clear then mount to the brass, but have no idea where to get the brass cut to size from, any one have any suggested suppliers?
You will kill the brass finish doing this as the clear vinyl will most likely not be optically clear and the chances of you getting it on perfect every hit is few and far between at that size.
If you really must use print onto brass, then apply the sheet of prints in one go using a mounter of some sort.
then have it cut to size.
Please note:
