Home Forums Sign Making Discussions General Sign Topics Supplier of material to make a stencil for concrete floor?
  • Supplier of material to make a stencil for concrete floor?
    Posted by Craig Bond on 17 June 2008 at 14:54
    I have a customer who requires some stencils for the floor of his factory. The floor is a skimmed concrete one so it is quite smooth. He is using plywood stencils at the moment with a liquid paint but his paint is seeping under the plywood and making a mess of his letters. The stencils need to be re-usable.
    Has anyone made stencils like this before and also what sort of paint should he be using?
    The area to be stenciled is about 4ft x 4ft.
    Any help or ideas would be greatly appreciated.
    Craig
    Craig Bond replied 17 years, 6 months ago 4 Members · 4 Replies
  • Fran Hollywood
    17 June 2008 at 18:30
    The customer could reuse his plywood stencils but use a rubber trim, on the edge of the letter, to stop the paint from spreading out. I saw a board that used a draft excluder type of strip pinned to the edge, it helped to prevent the bleeding of the paint.
  • Craig Brown
    17 June 2008 at 20:36
    Give AT Brown a call very helpful and stencils is their game.
    http://www.atbrown.co.uk/comersus/store/comersus_stencils.asp
    Paint wise go for a spray can and an old trick is to knock the bottom out of a cardboard box, place that over the stencil and spray into the box (stops all the over spray) that’s how I used to do Skips for one of our old customers and it worked a treat. 😎
  • John Harding
    17 June 2008 at 22:46
    Apply vinyl graphic to garden pond liner butyl rubber Cut stencil out, and spray through, thats what a mate of mine does dunno what paint though – hope it helps
  • Craig Bond
    18 June 2008 at 07:10
    Thank you to you all for your replies
