Home Forums Sign Making Discussions General Sign Topics supplier needed please of outdoor display cases required
  • supplier needed please of outdoor display cases required
    Posted by Derek Heron on 4 February 2008 at 09:45
    Morning
    i am looking for similar as the attached pdf
    they are to fit to 40mm square rail
    does any body know of a supplier or will they have to be specially made the ones pictured look just that
    any ideas please
    Derek
    mod-edit
    please use the correct forum when posting
    this post has now been moved. :police3:
    Derek Heron replied 17 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
    4 February 2008 at 09:50
    Derek although this company is local to me I never used them, but they do a large range of display cases, I got their brochure a few weeks ago.
    web is http://www.artillus.com
  • David Lowery
    4 February 2008 at 09:53
    They are definitely a special. Welded frame fitted with standard channel and clips. Sorry Derek 🙁
  • David Lowery
    4 February 2008 at 10:21
    Derek, have a look at the screws and if the allen screw heads have a central pin in them as a security thingy, then these could have come from Horizon Marketing, a good supplier of poster frames etc.
    http://www.horizon-signs.co.uk/
    4 February 2008 at 10:25
    looks like they could be pretty easily made?
  • Derek Heron
    4 February 2008 at 11:36
    thanks for the replies
    i looked for a local metal fabricator
    and their is one just around the corner
    so waiting for a price for frames.
    any suggestions as to what to use for the facia as needs to be scratch resistant. am going to use alupanel for the base and as the photos channel and clips for fitting .
    cheers for the replies
    derek
  • David Lowery
    4 February 2008 at 12:56
    Polycarb 😕
  • David Lowery
    4 February 2008 at 13:01
    quote Derek Heron:
    derek
    Would suggest you use aluminium throughout. If you use alupanel and rivet channel to it, it will just pull off by the nearest numbskull. It looks to me like a folded tray base with the frame fitting over it so that it stops water ingress.
  • Derek Heron
    4 February 2008 at 13:30
    cheers dave see what you mean
    Derek
