Home Forums Sign Making Discussions File Swapping Supagard Logo required (valeting)
  • David Rogers
    21 June 2006 at 13:36
    Just ripped this from your jpg…. it’s pretty good.
  • David Norris
    21 June 2006 at 13:40
    Wow, thats spot on thanks David.
    I did try the Trace feature in CS2 but to no avail.
    Thanks again.
  • David Rogers
    21 June 2006 at 14:01
    What signmaking package have you got. Flexi, Easy, Signlab, Corel….
  • David Norris
    21 June 2006 at 14:04
    Signlab, but I do all artwork in Illusrator and just use Signlab for the cutting.
  • David Rogers
    21 June 2006 at 14:31
    Probably as you’re comfortable with Illustrator for designing – Signlab is incredibly capable (as I did above) of converting even rough images to nice vectors very quickly. I honestly took about 1 minute to complete it.
    For that image:
    Copied & Pasted direct from web. Double click image – posterise to 2 colours (in this instance), trace setup at: Tolerance 9, Corners 6, Speckle 3, Snap H/V OFF, Small Shape OFF.
    Then just hit ‘Vectorisation’ and see the results.
    Picking the numbers can be a bit of a lottery to begin with until you get a ‘feel’ for what will happen.
  • David Norris
    21 June 2006 at 14:34
    Thanks dave, I will give that a try.
