Home › Forums › Sign Making Discussions › Vinyl › Sunstrips legal size for Cars. Advice please?
Tagged: .gov, capri, car, government, M.O.T., sun-strip, sunstrip, sva, truck, van, vosa, windscreen
Posted by Micheal Donnellan on 14 July 2006 at 21:40hello all
A simple question I hope. Is there a limit as to the size of the sunstrip?
I have this idea in my head it was 5″ but several cars have 10″ strips.
So does anyone know if there is a legal limit or recommended maximum depth for a Sunstrip?Sunstrips, sunstrip, sun strips, windscreen, Car, #sunstrip #sunstrips @sunstrips @sunstrip
Adam McGuire replied 19 years, 5 months ago 8 Members · 17 Replies -
The LEGAL requirement is:
Must NOT be into the area swept by the wiper – fitting smaller wipers is a no-no!
Generally speaking, this is ignored – 5 or 6" strips are the norm and nobody gets pulled for them.I have seen Boy & Girl racers with strips about a third of the way down the screen, but not there for very long though as the Police do not take kindly to them.
____________________________________________________________________________
Sunstrips, sunstrip, sun strips, windscreen, Car, #sunstrip #sunstrips @sunstrips @sunstrip -
The legal requirement for an M.O.T. is that the only thing that may be affixed to a windscreen is the tax disc or a disabled badge. so anything else is a no-no. But as most trivial laws are not enforced, I wouldn’t worry about it
thanks for the replies.
Not being swept by the windscreen wipers means very narrow strips on a lot of carsDoes anyone know if sun strips are allowed by the NCT? which is known as the Irish M.O.T.
I doubt it, Micheal.
Just fit them after the M.O.T. has been done.
As long as you tell the customer!
And if it fails the next year, you get a return job from it!Peter
Hi all…
Slightly incorrect info about the sun strip and M.O.T.
If you drew a line up from the middle of the steering wheel, the windscreen wipers must not travel into the sunstrip by any more than 10mm. Anywhere else on the screen the wipers must not travel into the strip by any more than 40mm
Good for repeat business though.
I had one the other week on a Celica.Info from my girlfriend’s Dad who works at VOSA doing SVAs.
Guidance
View to the front and windscreen obscurationGOV.UK
General requirementsRegulation 30 of the Road Vehicles (Construction and Use) Regulations 1986 (SI 1986 No. 1078 as amended) requires that:
(1) Every motor vehicle shall be so designed and constructed that the driver thereof while controlling the vehicle can at all times have a full view of the road and traffic ahead of the motor vehicle.
(2) Instead of complying with the requirement of paragraph (1) a vehicle may comply with Community Directive 77/649, 81/643, 88/366, 90/630 or, in the case of an agricultural motor vehicle, 79/1073.
(3) All glass or other transparent material fitted to a motor vehicle shall be maintained in such condition that it does not obscure the vision of the driver while the vehicle is being driven on a road.In practice, the annual test will check that items placed in or stuck to the windscreen or surface damage, cracks or discolouration in the windscreen do not seriously obscure the vision of the driver. In order to better define what maybe permissible the windscreen is divided into zones:
Zone A is a vertical area 290mm wide, centred on the steering wheel and contained within the swept area of the windscreen (this area is 350mm wide on vehicles over 3.5 tonnes);Zone B is the remainder of the swept area of the windscreen
For simplicity, surface damage, cracks or discolouration, are simply referred to as damage.
In Zone A, a single damaged area shall be contained within a 10mm diameter circle. A combination of minor damage areas shall not seriously restrict the drivers view. Windscreen stickers, or other obstructions, shall not encroach more than 10mm.
In Zone B, a single damaged area shall be contained within a 40mm diameter circle. Windscreen stickers, or other obstructions, shall not encroach more than 40mm.
Windscreen repairs shall be assessed the same as unrepaired damage and shall not restrict the driver’s vision.
Cracks passing through the swept area of the windscreen and reaching two points at the edge shall be deemed to render the windscreen insecure.
Items placed in, or stuck to, the windscreen could be stickers, pennants, satellite navigation monitors or decorations.
Original vehicle design features and drivers aids, such as sun visors, are allowed.
Vehicles that do not comply with the above could be construed to be in contravention of the legislation.
Additionally, Regulation 100 of The Road Vehicles (Construction and Use) Regulations 1986 (SI 1986 No. 1078 as amended) requires:
a motor vehicle, and all its parts and accessories;the number of passengers carried, and the manner in which any passengers are carried in or on a vehicle; andthe weight, distribution, packing and adjustment of the load of a vehicle
to be at all times such that no danger is caused, or is likely to be caused, to any person in or on a vehicle or on a road.
Further to this, Section 40a of The Road Traffic Act 1988 (as amended by Section 8 of the Road Traffic Act 1991)Part II, Using a Vehicle in a Dangerous Condition, states that:
A person is guilty of an offence if he uses, or causes or permits another to use, a motor vehicle or trailer on the road when:
(a) the condition of the motor vehicle or trailer, or of its accessories or equipment, or
(b) the purpose for which it is used, or
(c) the number of passengers carried by it, or the manner in which they are carried, or
(d) the weight, position or distribution of its load, or the manner in which it is secured, is such that the use of the motor vehicle or trailer involves a danger of injury to any person.Consolidated versions of national regulations can be found in Sweet and Maxwell’s ‘Encyclopaedia of road traffic law and practice (construction and use)’ which should be available at most main reference libraries.
Copies of national regulations can also be purchased from:
TSO Orders/Post Cash Department
PO Box 29
Norwich
NR3 1GNTelephone: 0870 600 5522
Fax: 0870 600 5533
Email: customer.services@tso.co.uk
Website: http://www.tso.co.uk____________________________________________________________________________
GOV.UK
Terms and conditionsThis page and any pages it links to explains GOV.UK’s terms of use. You must agree to these to use GOV.UK.
Who we are
GOV.UK is managed by Government Digital Service (GDS) on behalf of the Crown. GDS is part of the Cabinet Office and will be referred to as ‘we’ from now on.
Using GOV.UK
You agree to use GOV.UK only for lawful purposes. You must also use it in a way that does not infringe the rights of, or restrict or inhibit the use and enjoyment of, this site by anyone else.
We update GOV.UK all the time. We can change or remove content at any time without notice.
Services and transactions
You can use GOV.UK to access online government services and transactions, for example, GOV.UK Verify or register to vote.
These can be managed by GDS or another government department or agency.
Some services have their own terms and conditions which also apply – read these before you use the service.
Linking to GOV.UK
We welcome and encourage other websites to link to GOV.UK.
You must contact us for permission if you want to either:
charge your website’s users to click on a link to any page on GOV.UKsay your website is associated with or endorsed by GOV.UK or another government department or agency linking from GOV.UK
GOV.UK links to websites that are managed by other government departments and agencies, service providers or other organisations. We do not have any control over the content on these websites.
We’re not responsible for:
the protection of any information you give to these websites any loss or damage that may come from your use of these websites or any other websites they link to
You agree to release us from any claims or disputes that may come from using these websites.
You should read all terms and conditions, privacy policies and end-user licences that relate to these websites before you use them.
Using GOV.UK content
Most content on GOV.UK is subject to Crown copyright protection and is published under the Open Government Licence (OGL).
Some content is exempt from the OGL – check the list of exemptions.
Departmental logos and crests are also exempt from the OGL, except when they form an integral part of a document or dataset.
If any content is not subject to Crown copyright protection or published under the OGL, we’ll usually credit the author or copyright holder.
You can reproduce content published on GOV.UK under the OGL as long as you follow the licence’s conditions.
Contact us if you want to reproduce a piece of content but are not sure if it’s covered by Crown copyright or the OGL.
We make most of the content on GOV.UK available through feeds for other websites and applications to use. The websites and applications that use our feeds are not our products, and they might use versions of our content that have been edited and stored for later use (‘cached’).
We do not give any guarantees, conditions or warranties about the accuracy or completeness of any content used by these products. We’re not liable for any loss or damage that may come from your use of these products.
The most up to date version of our content will always be on GOV.UK.
Disclaimer
While we make every effort to keep GOV.UK up to date, we do not provide any guarantees, conditions or warranties that the information will be:
current secure accurate complete free from bugs or viruses
We do not publish advice on GOV.UK. You should get professional or specialist advice before doing anything on the basis of the content.
We’re not liable for any loss or damage that may come from using GOV.UK. This includes:
any direct, indirect or consequential losses and loss or damage caused by civil wrongs (‘tort’, including negligence), breach of contract or otherwise the use of GOV.UK and any websites that are linked to or from it the inability to use GOV.UK and any websites that are linked to or from it
This applies if the loss or damage was foreseeable, arose in the normal course of things or you advised us that it might happen.
This includes (but is not limited to) the loss of your:
income or revenue salary, benefits or other payments business profits or contracts opportunity anticipated savings data goodwill or reputation tangible property intangible property, including loss, corruption or damage to data or any computer system wasted management or office time
We may still be liable for:
death or personal injury arising from our negligence fraudulent misrepresentation any other liability which cannot be excluded or limited under applicable law requests to remove content
You can ask for content to be removed from GOV.UK. We’ll remove content:
in order to comply with data protection legislation covering the rights and freedoms of individuals if it breaches copyright laws, contains sensitive personal data or material that may be considered obscene or defamatory
Contact us to ask for content to be removed. You’ll need to send us the web address (URL) of the content and explain why you think it should be removed. We’ll reply to let you know whether we’ll remove it.
We remove content at our discretion in discussion with the department or agency responsible for it. You can still request information under the Freedom of Information Act and the Data Protection Act.
Information about you and your visits to GOV.UK
We collect information about you in accordance with our privacy policy and our cookie policy. By using GOV.UK, you agree to us collecting this information and confirm that any data you provide is accurate.
Virus protection
We make every effort to check and test GOV.UK for viruses at every stage of production. You must make sure that the way you use GOV.UK does not expose you to the risk of viruses, malicious computer code or other forms of interference which can damage your computer system.
We’re not responsible for any loss, disruption or damage to your data or computer system that might happen when you use GOV.UK.
Viruses, hacking and other offences
When using GOV.UK, you must not introduce viruses, trojans, worms, logic bombs or any other material that’s malicious or technologically harmful.
You must not try to gain unauthorised access to GOV.UK, the server on which it’s stored or any server, computer or database connected to it.
You must not attack GOV.UK in any way. This includes denial-of-service attacks.
We’ll report any attacks or attempts to gain unauthorised access to GOV.UK to the relevant law enforcement authorities and share information about you with them.
Governing law
These terms and conditions are governed by and construed in accordance with the laws of England and Wales.
Any dispute you have which relates to these terms and conditions, or your use of GOV.UK (whether it be contractual or non-contractual), will be subject to the exclusive jurisdiction of the courts of England and Wales.
General
There may be legal notices elsewhere on GOV.UK that relate to how you use the site.
We’re not liable if we fail to comply with these terms and conditions because of circumstances beyond our reasonable control.
We might decide not to exercise or enforce any right available to us under these terms and conditions. We can always decide to exercise or enforce that right at a later date.
Doing this once will not mean we automatically waive the right on any other occasion.
If any of these terms and conditions are held to be invalid, unenforceable or illegal for any reason, the remaining terms and conditions will still apply.
Changes to these terms and conditions
Please check these terms and conditions regularly. We can update them at any time without notice.
You’ll agree to any changes if you continue to use GOV.UK after the terms and conditions have been updated.
Good info Garrie.
My information came from an MOT tester, he was probably just playing it safe.
You can read the requirements in the Government M.O.T. Testers Manual:
https://www.gov.uk/topic/mot/manuals
I usually do the sunstrip in a medium window tint film, on the inside, or use external film. This way, you can still see through.
I have been told that 6 inches at the centre are OK, so usually, the extreme edges are about 8 inches deep.
Adam
Great link the MOT manual (will save in my favorites), confirms my post above..
Reason for rejection
1. A Windscreen sticker or other
obstruction encroaching more than 10mm2. A Windscreen sticker or other
obstruction encroaching more than 40mm____________________________________________________________________________
I fitted this one last Thursday and my golden rule is:
If it obstructs the driver’s vision, then it’s too big. I got the owner to sit in the car whilst I offered it up and when he gave me the thumbs up, I taped it into place.Note: This one was 4.5" in the centre, about 7.5" at the outer edges.
Bottom line is, I don’t want the Police knocking on my door claiming the sun strip I fitted was partly the cause of an accident. Call me cynical, but for a £40 job?
Cheers,
Gwaredd.____________________________________________________________________________
quote Steele Signs:I fitted this one last Thursday and my golden rule is:
Note: This one was 4.5″ in the centre, about 7.5″ at the outer edges.
Cheers,
Gwaredd.it is still illegal…
I make my customer sign a disclaimer, just in case.____________________________________________________________________________
Sorry folks, Disclaimers don’t mean a thing!
Law of the land and consumer rights always prevail, It is like Sainsbury’s putting a notice up saying they aren’t responsible for food poisoning if they sell you an out of date product.Peter
I just do not do sun strips, there is no point.
They are not signs and I do not think that they are worth the bother.
If someone comes to me and asks for a sun strip I offer to sell them a piece of vinyl to fit themselves.____________________________________________________________________________
quote Steele Signs:I fitted this one last Thursday, & my golden rule is: If it obstructs the drivers vision, then it’s too big. I got the owner to sit in the car whilst I offered it up, & when he gave me the thumbs up, I taped it into place. Edit: This one was 4.5″ in the centre, about 7.5″ at the outer edges.
Bottom line is, I don’t want a copper knocking on my door claiming the sun strip I fitted was partly the cause of an accident. Call me cynical, but for a £40 job…?
Cheers,
Gwaredd.
What happens when you have a short driver? can you lower the strip?
People who want a sunstrip on their Porsche must be a sandwich short of a picnic anyway, so £40 is far too cheap.
Give it to them large, it has got to be worth at least a £100.Peter
quote Peter Normington:Sorry folks, Disclaimers don’t mean squat, law of the land and consumer rights always prevail, Its like Sainsbury’s putting a notice up saying they aren’t responsible for food poisoning if they sell you an out of date product.
PeterI feel I must elaborate.
Disclaimers are often talked about on the boards, but under UK law, are very rarely a legal defence.
As a supplier, you have a duty of care to supply goods fit for the purpose. So if boy racer asks for a sunstrip, and you supply one that subsequently causes an M.O.T. failure, or god forbid, an accident, then under current law, you could be held culpable. It is simply not good enough to get the customer to sign a disclaimer.In fact, in some cases, asking for a signed disclaimer is in itself an admission that you are aware that the law is being broken.
Sorry to sound like a righteous scaremonger, but that’s how I see it.
I feel I must defend the Porsche owner by saying that it was not his idea to fit the sunstrip, but the Tuning firm that has just squeezed 520-odd bhp out of the said car & was going on an 8-day jaunt around Europe with other like-minded petrol heads, so it was a clever bit of advertising.
The tuning firm is having a load of gerber’d stickers off me too, hence the price Peter. I’m not normally that cheap 😉 But for the record, I hate doing sun-strips too, especially on £90k’s worth of the car, makes me nervous, but give me a £250k coach to letter, and I’m fine.
I only sell sunstrips, I do not usually fit them.
It is the same story with my mates number plates. They are "for show and offroad use only".They fit them, so as far as I am concerned, it is their problem.
If I went into a gun shop to buy a gun, I could take it home and put it on the wall or own it for perfectly legitimate reasons. But then I could also go out on a mad rampage through town. does that mean the bloke in the Gunshop could be prosecuted?
I’m not so sure it does. At the end of the day, it is legal to sell something for a particular purpose.
i.e. the "show plate" or "sunstrip for offroad and show use"
but what the customer does with it, we have no control!Just my thoughts on this.
Adam
