Home Forums Vinyl Cutter Discussions Summa Cutters Summacut D75 question about feed
  • Summacut D75 question about feed
    Posted by Graham Parsons on 18 January 2018 at 20:36
    Hi, Does anyone know – is there a way of adjusting the amount of feed after the job has cut? At the moment, the tail end of the job doesn’t quite clear the slot that you can run the razor-blade trimmer along – we have to manually move it forward to clear it on each job. I can’t seem to find anything in the manual.
    Alex Crosbie replied 7 years, 11 months ago 3 Members · 3 Replies
  • Pane Talev
    18 January 2018 at 21:39
    I move 30mm before making a cut on the D120. I’m also interested in solution, if any.
    19 January 2018 at 12:31
    Yup – same here. My old summa used to have a jog button that fed the vinyl forward, my new one doesn’t have this feature anymore. Seems they’ve done away with it unless there’s an alternative to manually jogging the vinyl forward?
  • Alex Crosbie
    19 January 2018 at 14:42
    The S-class will do it… it’s called cut off margin and accessed via the menus on the machine.
    The D-class as far as I’m aware doesn’t have it on the machine itself but if you use winplot then you could do it from there… screenshot attached
