Home Forums Vinyl Cutter Discussions Summa Cutters Summacut D120 cut misalignment
  • Summacut D120 cut misalignment
    Posted by Blidaru Madalin on 27 August 2016 at 20:49
    Hello guys. I have this problem with the cutter (photo attached). Is is an alignment problem from the cutter itself? I dont think the software have something to do with that. If is the alignment, witch one is it? I have to mention that the plotter was not used for some good time before this.
    Much appreciation,
    BM
    Blidaru Madalin replied 9 years, 4 months ago 3 Members · 4 Replies
  • Kevin Flowers
    27 August 2016 at 21:30
    Have you done the print & cut alignment process thats in the menu, basically you print a black square & the tell the cutter to fine it. Been a while since i’ve had a Summa so you’ll have to read the manual to get full process
  • Blidaru Madalin
    28 August 2016 at 06:01
    Thanks Kev.
    I have done the basic cut & alignment process that the cutter asks for, after sending the graphic to cutter. Will go trough some more manuals and see if i can find anything.
    Have a nice day!
    28 August 2016 at 13:27
    What printer and RIP software are you using?
  • Blidaru Madalin
    28 August 2016 at 13:41
    The printer is a Hp Designjet z6100. Unfortunatly we dont use a RIP software.
