Home Forums Vinyl Cutter Discussions Summa Cutters Summa D60 right pinch roller error
  • Summa D60 right pinch roller error
    Posted by MilosV on 3 November 2016 at 08:43
    Hello,
    here I am after long time.
    I’m having an issue with the SummaCut D60R.
    Sometimes when I laod the media, I get an error message on the LCD screen: "Right pinch roller is not set properly above a sleeve! Raise the pinch rollers and set them correctly."
    This would seem easy fix, but the problem is that the pinch rollers are both set properly above a sleeve. When I push the head back and restart machine with switch off/on it normally works. I even try to clean the sensor but the problem remains.
    Any tips or what I need to do to fix this?
    Regards, Milos
    MilosV replied 9 years, 2 months ago 1 Member · 0 Replies
