Home Forums Vinyl Cutter Discussions Summa Cutters Summa D1400 pro. Odd cut marks
  • Summa D1400 pro. Odd cut marks
    Posted by David Rogers on 1 April 2017 at 00:02
    Since ‘messing about’ getting the OPOS to work the machine has developed a quirk.
    Next to every letter / shape the machine puts a small 0.25mm cut about 2mm away from it.
    Shows up even in the onboard test cut / sample sequence so not software related.
    I think SOMETHING got reset or changed that shouldn’t be but it runs perfectly otherwise.
    Anybody know what would be causing this and a solution?
    Thanks Dave
    David Rogers replied 8 years, 9 months ago 2 Members · 4 Replies
    1 April 2017 at 06:46
    Morning
    Don’t know about a summa but on a graphtec it’s called blade control
    Set within the menu and can be 2mm inside or outside a starting path loop
    1 April 2017 at 07:01
    Might be called OptiCut on the summa
  • David Rogers
    1 April 2017 at 21:54
    Thanks Chris will get a look at that Monday.
  • David Rogers
    3 April 2017 at 22:52
    Spot on with the opticut setting.
    Must’ve been turned on during the opos setup.
