Home Forums Vinyl Cutter Discussions Summa Cutters Summa Cutting poorly?
  • Summa Cutting poorly?
    Posted by Johnny Alston on 1 February 2011 at 15:53
    New blade fitted and cutter is having a nightmare.
    tried several blades and cant get a clean cut on 10mm text when weeding its lifting.
    have had pressures all over the place no different
    have slowed everything right down no difference
    any advice welcome.
    Hugh Potter replied 14 years, 11 months ago 5 Members · 6 Replies
  • Gary Birch
    1 February 2011 at 16:07
    New blade holder? If not even just a clean and a drop of 2in1 oil?
    Gary
  • Harry Cleary
    Have you tried playing with the blade offset….would be fairly critical at those sizes.
  • Steve McAdie
    1 February 2011 at 16:52
    Is the cutting strip in good condition?
    1 February 2011 at 17:11
    quote Steve McAdie:
    my first thoughts too. if you scratch your fingernail across the strip back to front, it should feel smooth, if any deep ruts that catch your nail then it’s time to replace.
    edward mathias would be a good start for the strips.
    what blades are you using? as said above, the offset would be critical at that size.
    Hugh
  • Johnny Alston
    1 February 2011 at 18:54
    Cutting strip is is in good nick
    blades from Edward Mathias
    its a tangential head but have changed lateral compensation
    have tried using flexi settings and on machine settings
    got a bit better but still not as good as it should be.
    1 February 2011 at 22:11
    blade offset on the mathias blades, if i recall, is .48mm. worth checking.
