Home Forums Printing Discussions Sublimation Printing sublimation printing with epson printer – some questions
  • sublimation printing with epson printer – some questions
    Posted by Sarah-jayne on 11 August 2011 at 20:27
    Some really basic questions here – I have an Epson Stylus B1100 which I bought to do some A3 photographs and I now just use it for every day printing but I was wondering about using it with sublimation inks – I have looked at the continuous ink systems and I assume they are easy to install – am I correct? Is there any problem ordering them from China, I was looking on ali express.
    Can I switch from the sublimation back to durabright if I wanted to print any A3 photos or am I better to buy an older epson – I’ve seen an R1800 quite cheap – second hand with a set of inks.
    I wont be doing loads of printing – I have to fit this around my day to day stuff, so the printer might not be used constantly.
    Also is my basic belief that I buy the right type of paper, print with the sublimation ink and then heat set – is that correct? Or am I missing any vital bits out? Sorry if this sounds really dumb – I’ve read the forums and this is the blanks I still need filling!
    thanks
    Sarah-jayne replied 14 years, 4 months ago 6 Members · 11 Replies
  • 11 Replies
  • Mo Gillis-Coates
    11 August 2011 at 23:14
    Hi Sarah-Jayne, this will be brief, i’m just off to bed… I have been there and done that, I ended up throwing the printer in the bin after a year. It all works fine and was great in principle and I produced loads with it, CISS and everything. BUT if you don’t use it on a daily basis, and at the right working temperature, the ink dries on the heads and you end up constantly cleaning the print heads… So much so that eventually I overloaded my head cleaning pads, got the hump and threw the whole lot in the bin….
    I invested a little more in a Ricoh printer fitted with sawgrass inks and get perfect results every time, the inks are gell and don’t dry up so you can use it as infrequently as you like (although I advise running a start up clean every few days, but remember that uses ink)
    Cost are:
    Printer: prices range from £120-£150 new and inks are £40 for small cart and £60 for large, you will need 4
    The magic touch will sell you a printer and ink for £275 + vat…
    Invest now, save later!
    regards
    BigMo
  • Sarah-jayne
    11 August 2011 at 23:26
    thanks for that – appreciate it. Maybe try and get some income with what I have and leave this for a little later down the line – or perhaps try to find somebody to outsource to for now.
    12 August 2011 at 09:27
    quick couple of points. Firstly you can change the ink back from sublimation to regular cartridges BUT it will cost you quite a lot of money everytime you do it because of the ink you waste. The machine would need to be flushed through and cleaned thoroughly each time you switched inks.
    Secondly as Mo has said you need to be using the printer on a regular basis because the inks (sublimation) very quickly dry and clog the heads. If you don’t have regular work for this sort of thing then maybe best to leave it until you have. Don’t do any of this sort of work so don’t know how easy it is to sub out but with some things it is better to grow the business to a certain level using a trade supplier before you invest in your own equipment.
    Lastly, it’s great to be able to buy stuff cheaply from places like china but just remember if your running a business then stuff has to work properly when you need it to and if it doesn’t then you need to sort things quickly which means having proper support.
  • John Gregson
    12 August 2011 at 09:34
    Ad Mo said above, a Ricoh would be the way to go as the inks just don’t clog as much as the Epsons, even when left for long periods.
    Cheers John
  • Sarah-jayne
    12 August 2011 at 09:36
    quote Martin:
    thanks – something else for the wish list for now. although I think the other system Mo posted about seems much better and not as expensive as I thought – I’d looked at an Epson stylus 1400 and converting my £190 printer seemed a good idea compared with spending £500 for that. But it’s not what I need right now. (Focus woman, focus!)
  • Sarah-jayne
    12 August 2011 at 09:39
    quote John Gregson:
    Cheers John
    This crossed my post – thanks. I think I am going to go down that road in the future. Think perhaps if I actually know what I want to print and have the designs done and try and get a printer to earn its keep from day 1 might be a better idea. My enthusiasm is getting the better of me right now…
    12 August 2011 at 09:44
    Do you have a heat press? If not then that’s another expense you have in setting up to do sublimation printing no matter what you do printer wise.
    Your asking a lot of questions about different types of equipment, not a bad thing but just remember it is best to learn to walk before you run. Might be an idea to concentrate on just one area for now, make a bit of money and add other services as and when you have the money. What ever you do there are quite steep learning curves so may be best to tackle them one at a time.
    12 August 2011 at 10:01
    I wouldn’t consider Epson, I had sublimation set up with an Epson and spent more time cleaning and nursing the thing into life than I did working – total dead loss and binned it enventually. Ricoh sounds a good option though.
    Alan D
  • Graeme Harrold
    12 August 2011 at 10:30
    Poignant timing, just threw my 1400 in the bin today with a load of ink still in the bulk system. Just way too much trouble, yellow is the worst for clogging.
  • Mo Gillis-Coates
    12 August 2011 at 10:34
    gotta admit guys, although the prints are quite expensive to produce, the Ricoh was recommended by someone on here and it’s fantastic, also it prints really really fast which is a bonus.
    I’m considering getting another one just for printing my photos etc
  • Sarah-jayne
    13 August 2011 at 21:32
    quote Graeme Harrold:
    LOL – I was rather tempted to pay £117 for a second hand one on E-Bay but hey, I am learning!
