Home Forums Printing Discussions Sublimation Printing Sublimation Mug printing problem
  • Sublimation Mug printing problem
    Posted by Phil Jones on 30 March 2009 at 18:30
    Hi all,
    I have just bought a mug press to add to the sublimation side of my business and to be honest i am struggling a bit, every time i print a mug i end up with loads of little black spots all around the printed text so if i have a line of blue text for example i end up with my blue text which is fine but loads of tiny black spots all around the blue text, i am using xpres sublimation paper and mugs and i have the d88 sublimation setup from xpres too. Any help / suggestions would be gratefully received.
    Phil
    Phil Jones replied 16 years, 9 months ago 5 Members · 5 Replies
  • Justin Mann
    30 March 2009 at 19:59
    Hi Phil,
    Best advice would be to speak with Xpres tech. support, they are first class. You can speak to them through MSN at technical@xpres.co.uk.
    Cheers,
    Justin
  • Paul Humble
    30 March 2009 at 20:28
    Does the black look ok on the paper or not?
  • Paul S Martin
    30 March 2009 at 22:47
    Hi Ya
    1. Are you printing in standard mode & not Photo mode.
    2. when was the last time you did a head clean.
    3. has it done this from the word go.
    Again as JNMann said best if all goes out the window is to speak to xpres a very helpful bunch.
    Paul
  • Graeme Harrold
    31 March 2009 at 08:08
    Sounds like you are getting a fine mist of black on the paper that may not be noticed until its too late (on the mug). Check your print with a magnifying glass and look for the black spots on the paper.
    As said before, check your basic settings and do a head clean.
  • Phil Jones
    31 March 2009 at 20:49
    Thankyou Paul & Graeme changed from photo mode and did a head clean and problem solved. :thanks2:
