Home Forums Sign Making Discussions Vinyl Struggling with Glitter garment film to heat properly?
  • Struggling with Glitter garment film to heat properly?
    Posted by Russ Draper on 22 October 2006 at 22:22
    Hey folks just wondered what settings you use for glitter garment vinyl, I am having problem with it fixing to my shirts.
    I am pressing at 170 degrees for 20 secs and then waiting for it to cool before removing the carrier, but im finding that if i remove the carrier cold you really have to use some force to get it off and sometimes pulls some of the image….if try to remove whilst still hot or warm it tends to stick to the carrier and not the shirt!
    Any ideas please?
    R
    Russ Draper replied 19 years, 1 month ago 3 Members · 3 Replies
    22 October 2006 at 22:37
    this is not my Field mate, but I’m sure some of the member’s will be able to help on this, if not… Nigel at grafityp is sure to see it and help you tomorrow as grafityp do all these types of films.
  • Nigel Pugh
    23 October 2006 at 09:14
    Speak of the devil as to say 😀
    If it is the glitter film from our "fashion films" then the settings should be:
    150 C Temp , 10 – 15 seconds press time and washable upto 30 C max.
    At 170 C you are way too high and can adversely affect the application and life of the material.
  • Russ Draper
    23 October 2006 at 15:57
    Cheers for the reply, I got the glitter film from the vinyl corporation so I am not sure what brand it is!
    Are there limitations to what kind of text can be applied using this film? I ran a few more tests today and still struggled with the release!
    Will try lowering the temp tomorrow and try that, maybe the heat is welding the carrier to the film?
