Home Forums Sign Making Discussions General Sign Topics Strong Industrial Adhesive
  • Strong Industrial Adhesive
    Posted by Noel Anderson on 24 September 2010 at 14:01
    Hi All,
    We’ve had a bit of trouble with different bonding solutions here. What would you recommend for bonding large aluminium sheets over an old set of panels? I’ve heard Tec 7 is quite tough, but I doubt it could handle this?
    Thanks,
    Bob Clarkson replied 15 years, 3 months ago 2 Members · 3 Replies
  • Bob Clarkson
    24 September 2010 at 15:31
    Tigerseal every time, nothing sticks quite as good as that stuff, also don’t try and save a couple of quid buying cheaper, similar stuff. It’s never quite the same.
  • Noel Anderson
    24 September 2010 at 15:44
    Would it bond Alo to Alo? And how weather resistant is it. It seems to be for cars so I’d say is designed to stand up to strong vibrations.
  • Bob Clarkson
    24 September 2010 at 16:40
    It is clearly car orientated, but with regards to alloy, you can bond a Landrover wing on with it. I don’t know why it doesn’t appear in general building products, apart from as you say the need to withstand vibration. However, f you bonded two sheets of alloy together with it, they would be impossible to separate, without destroying them. It’s totally weather resistant, I stuck a boot spoiler on a Camaro ten years ago, and it’s still there, you’d bend the boot before you got it off. Whether or not it’s the right thing to use, I can’t say, but I can say it’s the best.
