Home Forums Printing Discussions Mimaki Printers Strange banding (fading) – Rockhopper 3 Wasatch
  • Strange banding (fading) – Rockhopper 3 Wasatch
    Posted by Conny on 12 September 2011 at 15:51
    Hello!
    I would really like to get some help on the "banding"problem we have (more like fading).
    The nozzlecheck looks perfect.
    The problem appears on PVC-banner and roll-upmaterial.
    It is noticible on green, blue and some orange colours. I’ve attached a picture that shows how it looks.
    If anyone have any ideas I’m thankful if you would like to share them.
    Reza Faezi replied 12 years, 2 months ago 7 Members · 8 Replies
  • 8 Replies
  • Kevin O Connor
    12 September 2011 at 22:11
    we use get this a lot with our printer, only started after we switched to third party inks and incorrect profiles. we would have to switch the machine from 2 passes to 4 pass and it usualy solved the problem
  • Conny
    13 September 2011 at 07:43
    We have never used any third party inks, and the profile is the same as we’ve always used.
    I’ve tried to lower the temp and it looks as if this works :/ It’s getting better but not perfect.
    Hmm, I will keep trying.
  • Gabriel Cristian
    13 September 2011 at 08:54
    What about a nozzle check? Did you made it? Any problems on Cyan?
  • Russell Huffer
    13 September 2011 at 09:00
    We had simaler problem with our Mimaki turned out to be dampers.
    Kind regards
    Russell.
  • Stafford Cox
    13 September 2011 at 12:01
    I’d go with cyan damper being blocked or buggered. The Mimaki’s used to suffer from this when the head slants were out but I can’t see any obvious calibration issues with that.
    Stafford
  • Radjin Nandpersad
    15 September 2013 at 23:08
    because I have the same problem
  • Radjin Nandpersad
    15 September 2013 at 23:12
    since a few days I have the same problem on a variety of media,
    I have tried everything,
    different media,
    heater on/of
    excluding roll up and roll down
    the print start acceptalble for 20 cm
    than is start to create banding
  • Reza Faezi
    16 September 2013 at 08:29
    If all of the above have been checked and are all ok, maybe your encoder wheel is dead. It turned out ours wes buckled and the wheel was rubbing on the sensor. Also we could hear a slight "Juddering" when moving the media forward or backwards. We had a similar issue with our mutoh valuejet, its definately worth a check
