• Straight Lines
    Posted by Jill on 4 February 2003 at 20:47
    Hi All,
    Is there an easy way to get a straight line of text on a pannel of a van that isnt square,how or what do you go with.we did a Vauxhal combo van the other day the side pannel slopes down towards the front so everything looks all to cock 😳 any suggestion please.
    many thanks
    steve & jill 😆
    Joe McNamara replied 22 years, 10 months ago 6 Members · 6 Replies
    4 February 2003 at 20:55
    hi jill… im pretty busy right now working on new sign shop, sorry i cant look these out but in the last few weeks i think there has been about 3 posts covering this subject… if you dont find them let me know ill post the links here later 😉
  • Deleted User
    Deleted User
    6 February 2003 at 15:15
    We run into that all the time. Measure off the pavement if it’s level, and that should put your copy right on track.
  • Fat Bob
    6 February 2003 at 18:03
    Hi Jill
    A very Big Thanks for Getting me out of the mire recently I have been going to send you a post but you now how it can be sometimes.
    Try getting a 1 mt steel rule from B&Q and sticking it to some magnetic
    tape then you can put it on the side of the van. Move it around till it looks right then take your measurements from it or use it as a guide.
    Once again thanks and regards to Steve.
    …………..FB
  • Jill
    6 February 2003 at 20:32
    Thanx bob, anytime you need a help out and your in the area give us a ring, be glad to help out if we can, or if you ever need to borrow Steves tower give us a ring.
    Jill & Steve
    7 February 2003 at 22:31
    Jill, as Robert has said there are quite a few posts about this so if you do a search you should be able to bring up quite a bit on the subject.
    Something I try to do on vans like Combos, Astras, Peugeots etc where you can get these sort of problems is warn the customer before we letter the van, this way they cant come back to you and tell you it is all squint. As has been said in previous posts however you end up measuring it tack the graphics in place step back and check it by eye before applying it. That way it is hard to go wrong. If it looks right by eye then you cant go far wrong.
  • Joe McNamara
    8 February 2003 at 19:10
    Well, Martin’s spot on…..can’t really add any more to that !
    Joe
