straight edge idea
I’ve been having a few problems lining up text on vehicles trying to find the best way to do it and resorted to using masking tape, only problem being you can run off line easy, then i thought about cutting a thin long bit of magnetics and it works a treat you can put it on the vehicle move it about and re-use it, because it sits flat on the surface you always have a straight line.
I’m sure others are already doing this but thought its a good idea.Maybe i should print some measurements on it and sell it.
Lee
