• Stolen letters
    Posted by Russell Spencer on 19 June 2007 at 14:51
    a customer has had some letters stolen of his facia, they were brush dibond and mounted on simplefix locators, they are out of reach to a degree (approx 2.5m) but someone has still managed to nick some of them. Anybody got any ideas on how to make them more secure? Glue is an obvious one but Externally I dont think this maybe suitable, I thought of drilling through the cup from the side and into the locator then putting a pin or nail in but its a lot off work.
    Anybody done anything else?
    Russell Spencer replied 18 years, 6 months ago 7 Members · 7 Replies
  • 7 Replies
  • David-Foster-
    19 June 2007 at 15:37
    If they are metal, connect them to the mains :lol1: (:)
    19 June 2007 at 16:13
    Use brass locator’s, these are threaded so to remove the letters they are going to have to come armed with a spanner.
  • David Rogers
    19 June 2007 at 17:05
    Really depends on whether the fixings are still in the locators or not!!
    I’ve done a few repairs on signs that the alloy / di-bond had parted company with the acrylic fixings to the point of dangling there by the last good bond – as the last company had used a mixture of araldite, foam pads & evo-stik…
    I tend to use a two-part superglue for a quick bond & back it up with ‘serious stuff’ these days – but it does take a couple of hours to ‘go off’ completely – but secure enough as the superglue (which would normally fail in a couple of years on its own) keeps them in place anyway.
    The brass ones Martin suggests are great – but mounting the males to the letters might be an issue (normally soldered to st/stl or brass letters) – I’m not sure about how to fix to anything else.
    19 June 2007 at 19:54
    quote David-Foster-:
    lol, that was my first thought when i read this earlier, i thought i’d save it til later… after someone had posted a sensible reply 😮 🙄 🙄 doh.
    19 June 2007 at 20:17
    If they can’t nick em, they will smash em anyway,
    so my theory is, if the are easy to remove little damage will be caused, so easy to replace anyway.
    If you have a no brain nicking odd letters hardly likely he will come back for the same ones 😀
    other alternative to electric, and I heard this from a Glaswegian girl, stick razor blades to the reverse side,
  • Phil Acko
    19 June 2007 at 23:25
    bit extreme for the fitter who has to take them down next init peter
  • Russell Spencer
    20 June 2007 at 08:47
    thanks all
