Home › Forums › Printing Discussions › General Printing Topics › Static Cling Vinyl, advice needed please?
Posted by Robert Neill on 21 August 2021 at 14:11Afternoon, i hope everyone is well.
Does anyone know a kind of general heat setting i should have my printer at for printing onto static cling vinyl ?
David Stevenson replied 4 years, 3 months ago 3 Members · 6 Replies -
Solvent ink?
From memory we’ve run it same as vinyl ~40 Print 45 Dryer.
Even so let the inks outgas for a day or two before giving them the customer, as the ink can still transfer to the window.
Hi David…. yes solvent ink
Thank You, I didnt want to run it to hot with it being a kind of funny material. So thats great 👍
We’d run it the same as David. Also we use Metamarks MD5 profile with it as it lays down a nice amount of ink. Of all the materials we have I think I hate applying static cling the most and avoid it if possible.
Why do you hate it so much David ? I have not printed on it much, but I do have an order which requires a lot of printing on it lol
One thing I’ve found is that first meter of so of the roll, seems to mottle, whether it’s the material attracting dust or contaminates when rolled up I don’t know.
I’ve a roll of the stuff, but rarely use it. Also when it’s cut it clings to the backing, so need a bit of care when handling them.
I’ve always found it very stretchy and tends to distort when fitting. If you remove the backing sheet before install it stretches badly when you fit it. This is especially noticeable on the edges. What I tend to do is leave the backing on, apply it, then remove the backing sheet. You need to be careful when removing the backing sheet as it lifts it from the glass and introduces air bubbles. I much prefer reverse printing on clear vinyl then laminating it with white vinyl. Nowhere near as easy to remove unless you use a clear material with removeable adhesive but much easier fitted.
