Home Forums Printing Discussions Sublimation Printing Starting up in Sublimation
  • Starting up in Sublimation
    Posted by Paul Larkin on 12 January 2009 at 15:59
    Hi everyone,
    Myself and my partner (The Missus) would really like to get into sublimation printing as another string to our bow so to speak.
    We are already kitted out to produce cut vinyl and have a heat press for heat transfer vinyl. We would like to be able to produce images on mugs and t-shirts as well as canvas if it’s possible??
    Can anyone give advice on all the equipment required and a guide to how much I’m looking at spending to get up and running. i will probably buy used equipment to start up. Also advice on a printer that I will be able to readily buy cartridges/ink for. And suppliers etc.
    Any info will be gratefully appreciated
    Paul
    John Thomson replied 16 years, 11 months ago 7 Members · 17 Replies
  • 17 Replies
    12 January 2009 at 16:20
    there are a few good threads on this have a search and loads of options will come up.
  • Stuart Davies
    12 January 2009 at 16:48
    hi
    we got all our gear from xpres
    very good gear and good back up service.
    be carefull buying secondhand.
    we use a epson 1400 which we also got off xpres but i think you can get it cheaper elsewhere.
    items we have
    epson 1400
    cis system with sawgras ink
    heat press
    mug press
    we also buy all our consumables from xpres
    hope this helps
    stu
  • Paul Humble
    12 January 2009 at 16:51
    I bought the full startup pack off XPres and I am completely staisfied.
  • Mark Jahn
    12 January 2009 at 19:59
    Printer Owners, Home to Gifts starting point.
    Can’t fault our 1400 for dye sub, so much so we bought another last week off Amazon for £199. Plan ahead by opting for A3 and you’ll not regret it.
    I’d never go second hand for anything dye sub related, particularly if you’re going to build a business around your set up.
  • Graeme Harrold
    12 January 2009 at 20:15
    Just bought the entire set up from Printer Owners just before Xmas. I did travel, got a hands on demo and then drove away with a car full of kit and printables. Bulk Ink is a must if you are serious.
  • Mark Jahn
    12 January 2009 at 20:20
    Ahh..so Martin cleared you out then Graeme :lol1:
  • Paul Humble
    12 January 2009 at 20:21
    The only issue I had with the 1400 was an airlock in the Cyan. I tried to clear it but my fat fingers managed to damage the bulk cartridge. No probs though as Xpres replaced free of charge.
    All round its a great printer, only needed to run the nozzle clean half a dozen times since April.
  • Graeme Harrold
    12 January 2009 at 20:30
    quote Mark Jahn:
    Yeh and I cleaned him out in return :lol1: He will be doing frosted glass mugs soon as he gave me 3 to try, very nice.
  • Mark Jahn
    12 January 2009 at 20:45
    quote Paul Humble:
    Have to agree with you Paul. Early on I learnt to make sure the printer was turned off straight after finishing printing to avoid head clogging. Can’t remember the last time I’ve had to do a head clean now.
  • Mark Jahn
    12 January 2009 at 20:46
    quote Graeme Harrold:
    I like the sound of that. The more he increases his range the more I’m using other suppliers less and less.
  • Paul Humble
    12 January 2009 at 20:55
    quote Mark Jahn:
    quote Paul Humble:
    Ive never thought of doing that, as the inks were just used at room temperature I never thought it would make a difference. Ill try that from now on though.
    I wouldnt mind seeing a pic of a printed frosted glass mug.
  • Mark Jahn
    12 January 2009 at 21:29
    I think the trick is in the shutting down/starting up Paul. Have you noticed when you do either the printer performs a mini clean… 😉
  • Paul Humble
    12 January 2009 at 21:40
    quote Mark Jahn:
    Yes, thats good point.
  • Stuart Davies
    13 January 2009 at 00:34
    the tech guys at xpres told me never to turn the printer off
    dont know what to do now
    stu
  • Paul Humble
    13 January 2009 at 00:37
    quote stuart davies:
    stu
    Do whatever has worked for you so far. Im going to give it a try even though I rarely get problems, but thats how I have learned most of the other bits.
  • Paul Larkin
    13 January 2009 at 16:40
    Guys,
    Thanks alot for your comments and advice I will seriously look into the options.
    Fortunately I already have a heat press so I may spend a bit extra on an A3 size printer.
    Paul
  • John Thomson
    13 January 2009 at 18:20
    I was under the impression that the advice not to turn the printer on and off was to save on expensive ink……..
