Home Forums Sign Making Discussions File Swapping stained glass
  • stained glass
    Posted by Derek Heron on 18 August 2004 at 09:51
    hi all on the cadge again
    i am looking for an image of stained glass window it is for the back of a high roof transit i am getting it printed elswhere i have been told 300dpi should be ok also looking for an image of a fireplace i have one on buisness card supplied but not sure how to go about getting it sorted to cut
    dale s replied 21 years, 3 months ago 3 Members · 5 Replies
  • magpie
    18 August 2004 at 16:07
    Hi Dex,
    I can’t help directly, but I think you may benefit from having a look at the service offered by Vectorwise.
    Cheers Pete
  • Derek Heron
    7 September 2004 at 09:12
    helo again probably a dumb question but here goes have had fireplace vectorized see attached but when it cuts it cuts single lines etc there must be a simple way of increasing the lines and then cutting round them if possible what is the best programe do do this
    cheers dex
  • dale s
    7 September 2004 at 09:22
    Hi Dex
    Have you tried putting an outline on the image and then using that as your cut path, remember to delete or weld out original or it will still cut in between your new cut path.
    Hope that some use to you
    Dale
  • Derek Heron
    7 September 2004 at 09:34
    which programme would you use for that
    dex
  • dale s
    7 September 2004 at 10:27
    You could use any program I have Sign Lab and coral draw
    In sign lab just put an outline on it
    In coral draw go to the outline tool select the required thickness then go to the Arrange drop down box then select convert outline to curves.
    if you dont have either of these programs then sorry i cant help anymore
    Hope you get sorted
    Dale
