Home Forums Software Discussions Corel Software Spot colour help
  • Spot colour help
    Posted by Neil Bainbridge on 22 September 2011 at 13:41
    Hi All
    i have just got a file off a customer and it is made up of lots of black parts and i need to make all the black parts a spot colour for versa works to print them jet black, but it will take me forever to change each bit!
    Is there an easy way to change all the black bits to a spot colour in one go?
    Thanks Neil
    Neil Bainbridge replied 14 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
    22 September 2011 at 13:47
    What software are you using?
    Illustrator has options where you can select the parts, and recolour them all the same.
    Can you convert the existing colour to a spot, then change the colour mix to that of the roland spot?
  • Neil Bainbridge
    22 September 2011 at 14:01
    Im using corel x3
    22 September 2011 at 14:03
    I’m no help then I don’t use corel.
    Illustrator has the option to select an object, then in the select menu, choose all with the same fill & Stroke.
  • Neil Bainbridge
    22 September 2011 at 14:07
    ok thanks david
    22 September 2011 at 14:08
    If you’re still stuck send over an EPS I will see what I can do.
  • Neil Bainbridge
    22 September 2011 at 14:24
    thanks what is your email
  • NeilRoss
    22 September 2011 at 14:27
    quote Neil Bainbridge:
    Hi All
    Thanks Neil
    Using Corel 12 here:
    Edit/Find and Replace/Replace Object…
    You can select a colour and change to another colour. Just follow the wizard. Works a treat in this version.
  • Neil Bainbridge
    22 September 2011 at 14:54
    Neil spot on thanks this worked a treat
    Thanks Again
