Home Forums Printing Discussions Roland Printers SP540V internal error
  • SP540V internal error
    Posted by Ben Shaw on 15 October 2007 at 08:41
    Hi there,
    My SP540V was working just fine yesterday, but today… I can print for about 30 seconds, then the printer says "cancelling job". When I try to turn it off it gives me either internal error 1650462 or 1280874. I haven’t changed anything since yesterday, except that I now have heaps of printing to do and no printer.
    Does anyone know the codes or a workaround?
    Ben Shaw replied 18 years, 2 months ago 3 Members · 4 Replies
  • David Rogers
    15 October 2007 at 08:57
    Did a yahoo search & came up with this from Dec 2005 on a U.S. printing forum.
    quote :
    OK I heard back from the tech and it looks like you may have a bad Servo board. Aparently there was a bad batch of boards with a weak solder joint that can cause problems as the machine heats up. You will need to contact your dealer so they can replace the board.
    quote :
    Alrighty then…
    they came today and replaced the servo board and everything is up and running again…
    they said that Roland had told them that there was a bad batch of them get out however my serial number showed that mine was not one of them…ya
    Might at least be a start.
  • Ben Shaw
    15 October 2007 at 09:07
    Sweet, thanks Dave. It has been hot today for the first time in a while, so I might try pointing all my fans and AC at the printer and turn the heaters down. See if that does anything.
    Thanks for the quick response.
  • Jason Xuereb
    15 October 2007 at 10:00
    What are you printing on? Is it a full roll? Have you tried prefeeding the media into the printer so it isn’t pulling the roll?
    Using I get a Motor Error when I have this problem. It’s worth a try.
  • Ben Shaw
    15 October 2007 at 10:11
    I haven’t had any problems with motor errors except for once when I lent against the roll while it was printing. It didn’t like that.
    I pointed 2 fans and an air conditioner at the machine and managed to get one of the jobs done. I also turned the heaters down a bit. I guess my servo board is overheating then, but keeping it cold makes it work. I will hopefully get someone out to fix that shortly, but thanks for the information Dave as I probably wouldn’t have tried cooling it otherwise.
