Home Forums Printing Discussions Printer Ink sp540v flashing for all ink cartridges at once? help please.
  • sp540v flashing for all ink cartridges at once? help please.
    Posted by Dan Osterbery on 22 October 2012 at 08:01
    Good Morning,
    we did our Monday morning manual clean as per normal, but as we finished the screen was flashing and beeping for all four inks to be changed, and we cant seem to remove this? Can anyone help?
    thanks
    Dan
    Versaworks is saying "paused cartridges uninstalled"
    Dan Osterbery replied 13 years, 1 month ago 5 Members · 11 Replies
  • 11 Replies
    22 October 2012 at 08:37
    may be a cart sensor error i would remove and refit the carts carefully, unless you already have done that, switch it off completely and restart.
    last thing you want mon morn.
  • Dan Osterbery
    22 October 2012 at 08:59
    thanks Chris, have taken them out put them back in with power on and power off, but cant seem to shift this!!
    Not great on a Monday morning!!!!
    thanks
    Dan
  • Joe Wigzell
    22 October 2012 at 13:34
    Hi Dan,
    Have you managed to fix your issue yet?
    It could be that your black in is playing up, are you using 3rd party cartridges? Try changing the black if you have spare as a check, or simply cleaning the bottom of the cart- perhaps using an alcohol based cleaner to wipe the chip. The machine reads from the black first so make sure that all is well there as a starting point!
    Hope you manage to get sorted 😕
  • Dan Osterbery
    22 October 2012 at 14:04
    Cheers Joe will try wiping the chips with alcohol and see if that works, I do have a spare black so can try that too. Will let you know.
    Dan
  • Dan Osterbery
    22 October 2012 at 14:28
    Bingo!!
    Thanks Joe! wiping with alcohol has worked we are now reading the carts again and can print! (as soon as black cart wiped problem solved! have wiped the others just in case afterwards! Also Roland eco sol max carts all originals)
    Very grateful!!
    Dan
  • Joe Wigzell
    22 October 2012 at 14:46
    Glad you’re back up and running 😀
  • John Harding
    24 October 2012 at 08:50
    Bizarre – read this post yesterday, then came in this morning to clean my versacamm and had the same error meassage during cleaning. Luckily i knew what to do – whipped the black out quick wipe with alcohol and bingo all up and running in seconds
    Thanks guys :thumbup2:
    Oh and all genuine carts
  • Dan Osterbery
    24 October 2012 at 08:54
    Thats the forum at its best!!! Well done Joe owe you one!! Maybe there’s a batch of wobbly cartridge chips??
  • Stafford Cox
    24 October 2012 at 12:47
    quote Joe Wigzell:
    Hi Dan,
    That’s some great info right there Joe, thanks for sharing.
    Stafford
  • Joe Wigzell
    24 October 2012 at 15:12
    😀 Always glad to share and help where possible!
  • Dan Osterbery
    26 October 2012 at 08:22
    Hi Joe,
    have another problem would love some help with please!
    http://www.uksignboards.com/viewtopic.p … 315#434315
    thanks
    Dan
