Home Forums Printing Discussions Roland Printers Sp300v vacuum setting
  • Sp300v vacuum setting
    Posted by Kelvin Rawles. on 20 October 2020 at 20:18
    I can seem to get my SP300v to print with strong vacuum.
    It’s set to 100% on the machine and if I do a Test Print from the control panel it does run full vacuum.
    So, I guess it must be Versaworks that’s causing the problem, but the Job Settings and the queue settings are “use printer settings’ . The machine waits, with full vacuum, and when Versaworks sends the job the vacuum drops down to what sounds like between 10% and 20%
    I’ve also tried changing Versaworks settings to ‘strong vacuum’ but the machine still drops back as soon as the job is sent.
    Any ideas?
    Phill Fenton replied 5 years, 2 months ago 2 Members · 1 Reply
  • 1 Reply
    21 October 2020 at 08:23
    I use troop but I believe it’s similar to versaworks. In my system you have to set each individual profile to control the vacuum – either by local printer control or by troop itself. Different profiles have different settings so check that the actual profile you are using is correctly set?
