Home Forums Printing Discussions Roland Printers Sp300v pump upgrade help
  • Sp300v pump upgrade help
    Posted by Damian Blackburn on 17 April 2013 at 15:31
    Hi all, I have just bought the upgrade pump and fitting kit for my sp300v. The kit didn’t come with intructions. Has anybody done this upgrade? Do the settings on the printer need changing? Does anybody have pictures of the pump installed? Thank you
    Stephen Ingham replied 12 years, 8 months ago 5 Members · 15 Replies
  • 15 Replies
    17 April 2013 at 15:50
    where did it come from.
    have not fitted one yet but i know on mine it needs the correct firmware update at the time of fitting.
  • David Rogers
    17 April 2013 at 16:52
    http://www.uksignboards.com/viewtopic.p … light=pump
    It’s pretty easy – involves fitting a new bracket and some pipework modification.
    Firmware is more to slow the motor down than anything else or you’ll hemorrhage ink.
    Updating firmware is easy – but you need to have access to the service mode that is correct for your current version.
  • Damian Blackburn
    17 April 2013 at 17:39
    Got the stuff from digiprint supplies. Think my firmware is 7.10 I will check out the link and get back to you. Thanks
  • Damian Blackburn
    17 April 2013 at 17:45
    When I enter service mode what do I change for the new pump? Where to the pipes go to? Thanks again
  • David Rogers
    17 April 2013 at 22:38
    To be honest it’s been over 3 years since I did it…and have tossed all of the info.
    Bought mine via Signmaster – and they sent / emailed a how to guide & talked though too.
    Best contacting DIGI first…if they sell it, maybe they will provide backup (LOL).
    There’s various settings buried in the pump parameters that need values set – none of which I can remember as I no longer run a 540v / cadet.
    Literally 2 minutes’ work.
    18 April 2013 at 07:33
    Here’s a picture of mine. The inlet tubes (coming from the capping stations) enter the pump at the bottom through the T piece.
    The exit tube (to waste bottle) connects to the top of the pump (with one half of the T piece blocked off).
    Sorry – Don’t know how to upgrade the firm ware, but as David says you will use more ink if this isn’t done (though it will not prevent you from using the machine meanwhile).
  • Damian Blackburn
    18 April 2013 at 07:46
    Thanks, that clears up the fitting side. Just don’t want to fit it until I know the settings to change. The picture helps loads though. I didn’t know the pump motor is turned 90 degrees.
  • Damian Blackburn
    18 April 2013 at 07:50
    I noticed on the picture you have only one pipe coming out for the waste. Does it matter if you have two? Would it get rid of the ink better? Thanks
    18 April 2013 at 07:55
    It wouldn’t make any difference. The flow rate is determined by the pump.
  • Stephen Ingham
    18 April 2013 at 11:32
    Hi, sorry if this is a little late but i have a paper copy of the PUMP KIT INSTALL GUIDE.
    I would be happy to scan it when i get in later this evening and email a copy to anyone who wants one.
    Stephen
  • Stephen Ingham
    18 April 2013 at 11:39
    Ignore that last post from me….here is a copy in pdf
    OOPS….file is too big
    Anyone needs a copy give me your email (as long as that doesnt break any board rules…)
    Hope it helps and isnt too late
    stephen
  • Damian Blackburn
    18 April 2013 at 11:47
    Please could you email it to me. d.blackburn1976@gmail.com that would be great thanks!
  • Stephen Ingham
    18 April 2013 at 11:55
    email replied
  • Damian Blackburn
    18 April 2013 at 12:08
    That’s amazing thank you very much.
  • Stephen Ingham
    18 April 2013 at 12:10
    Glad i can help, thats what these places are for, i have had lots of help and advice from people on here and it is always nice to be able to give a little back from time to time.
