Home Forums Vinyl Cutter Discussions Roland Cutters SP300 Revival
  • SP300 Revival
    Posted by Ben Dexter on 20 October 2008 at 13:12
    I was given a Roland SP300-V around 5 months ago,the machine has been set not used the whole time,I know that it needs new heads,but I was wondering what it will costs to get the machine back to fully working order,I know it’s hard without seeing it but a rough idea.
    It has been plugged in the whole time so when the machine beeps that it needs to clean it’s self it has done so.
    I spoke to Victory Designs and I had some help from Mat,he recommended I take out a Roland warranty with them which will cost 800 pounds,but it will also have to be switched back to the Roland ECO-SOL ink’s.
    Does this option seem like the right way to go?
    Regards,Ben
    Ben Dexter replied 17 years, 1 month ago 10 Members · 31 Replies
  • 31 Replies
  • Kevin Flowers
    20 October 2008 at 15:39
    Ben
    go the Roland route, they’ll basically refurb the machine & replace a majority of the ink train plus you will end up with a years warranty
  • Ben Dexter
    20 October 2008 at 16:09
    Hey Thanks Kev,
    yeah I’m thinking that too,I just wondered if there maybe any issues in getting Roland to replace parts,can they put problems down to wear and tear etc? I don’t want to go this route and an engineer come out and say ok you need this this and this which the warranty doesn’t cover.
    Thanks for your input.
    Ben
    20 October 2008 at 16:15
    Not sure what you are expecting from roland? I doubt if you can take out a warranty, then make a claim for repairs in retrospect.
    20 October 2008 at 16:32
    peter if its a cadet or versa being run on non oe inks roland due a special they convert it back change loads of stuff and 12 mts warranty.
    a spanking good deal
    20 October 2008 at 16:46
    Well in that case it is. do they change the heads as well though?
  • Ben Dexter
    20 October 2008 at 16:48
    Hey,
    I’m not sure,I’m just going off the advice I have been given so far.The warranty is threw Victory Design,The way Victory explained it was,they send out a Roland engineer,they asses the machine and tell Victory what parts they need,then the engineer then installs them, or that could have been for any ‘extra’ parts not covered by the warranty?
  • Steve McAdie
    20 October 2008 at 16:57
    Hi Ben,
    I enquired back in May about this offer, you can go straight to Roland and get it done. In May you had to purchase a Gold or Silver warranty and a full set of eco inks as well. I was under the impression you had to get the printer to them rather than them come to you but I might be wrong. I thought it was dearer than £800 but again I might be wrong. Also not everything will be covered as I recall it was the print heads, ink lines, caps & pump that were replaced.
    PS Glad to see you took our advice in the end. :lol1:
  • Ben Dexter
    20 October 2008 at 17:11
    OK,
    would there be any benefit to going direct to Roland? yeah I just realized why Victory were asking what cartridges etc the machine has,They did say I had to buy new ECO-SOL inks and the total bill was around 1200 pounds,plus VAT I think. when you say buying a full set of inks it’s just the cartridges right?
    what is the difference between Gold and Silver warranties?
    Thanks again,
    20 October 2008 at 17:47
    go straight to roland do not pass go or collect £200.
  • Steve McAdie
    20 October 2008 at 20:44
    Not sure on the difference between gold and silver warranties Ben, think you got immediate service with gold but had to wait in line on silver but not sure, best give Roland a call as the deal may have changed now. The full set was just that 4 cartridges CMYK. The reason that they do this deal is to get you back on their ink.
  • Jason Xuereb
    20 October 2008 at 22:42
    What wrong with it currently? Heads don’t fire?
    Tried soaking the heads?
  • Ben Dexter
    20 October 2008 at 23:02
    I tried everything to get the heads working about 6 months ago,eventually gave up and order 2 heads from the states,After weeks of waiting and a ‘claim’ made to Paypal,some heads finally turned up but they were wrecked,I think the guy sent them damaged to begin with,Paypal recovered me 150 pounds of the 450 I paid,After this i gave up on the printer.
  • Ben Dexter
    20 October 2008 at 23:04
    do you have a number for Roland in the UK Steve?
  • Steve McAdie
    20 October 2008 at 23:10
    Here ya go Ben
    Roland 0845 230 9060
  • Jason Xuereb
    20 October 2008 at 23:37
    So they don’t fire at all?
  • Ben Dexter
    21 October 2008 at 13:27
    Thanks Steve going to call them now,
    They do fire jason but half the nozzles are blocked or damaged,I soaked them for 24 hours when I was trying to fix the problem,I pushed cleaner thru them,nothing helped.
    Thank you,
  • Ben Dexter
    27 October 2008 at 14:42
    Just spoke to Roland,
    seems like the best way to go,She read off a huge list of parts they replace for 891 pounds plus VAT,but you also have to pay for the Roland ink which is 200 pounds.
    She is emailing me details as we speak, I’ll post them up when I receive it.
    Thanks,Ben
  • Ben Dexter
    27 October 2008 at 15:24
    As per our conversation Roland will convert your machine back to a genuine Roland Machine for the cost of £891.00 + Vat (silver Warranty – Pg 17 in attached brochure) for this price we will change:
    · FLUSHING TRAY
    · FLUSHING SPONGE
    · WICK FOR SPONGE
    · HEAD WIPERS
    · CAP TOPS
    · PUMP
    · PRINT HEADS
    · INK DAMPERS
    · ENCODER
    · ENCODER SENSOR
    · HEAD CABLES
    · HEAD COVER
    · SCAN AND FEED MOTORS
    · LINEAR BEARING
    · CUTTING CABLE AND GUIDES
    · BLADE AND BLADE HOLDER
    · All Visible COVERS
  • Steve McAdie
    27 October 2008 at 17:42
    Would be daft not to go with that, be like a new machine.
  • Martin Armitage
    27 October 2008 at 18:22
    In my last employment, we had to have a head changed and a replacement pump, with the callout charge it came to well over £1000, what they are quoting you sounds like a fantastic deal.
    Mart
  • Ben Dexter
    29 October 2008 at 18:34
    It is the way to go,but I don’t have 1300 pounds right now to throw at something that I’m not 100% sure will bring the money back in,
    So I think a bit of re search is in order,Thanks for the input,
    Ben
    29 October 2008 at 20:10
    quote Ben Dexter:
    Ben
    Ben, you have already thrown good money after bad,
    you have been given good advice from the boards,and despite all that, tried to do things on the cheap,
    You will get nothing for nothing, so if you cant afford it, why not stick with the day job, and stop wasting everyones time untill you can?
  • David Rogers
    29 October 2008 at 20:40
    Not the same SP300V as this oneis it….
    (deja vu)
    You want it fixed and making money…GET IN AN ENGINEER. Period.
  • Brian Hays
    29 October 2008 at 21:05
    Have I missed something. In your 1st post you said you were "given the machine" is that given as in given free? If you were & you still don’t think it’s worth spending £1000 on then perhaps you should pass it onto someone else that can make good use of it. Perhaps your future lies elsewhere.
    If I were given an SP300 I would be overjoyed at the thought I could get it up & running with a heap of new parts for £1000+vat. 😎
  • Brian Hays
    29 October 2008 at 21:07
    quote David Rogers:
    (deja vu)
    8 pages of ignored advice then a locked thread as it’s getting silly again is it? 😕
  • Graeme Harrold
    29 October 2008 at 21:17
    Same machine?? Same Ben Dexter??? (different post count)
  • Ben Dexter
    29 October 2008 at 23:30
    I have asked for your advice…I have taken it,however I don’t have the funds right now to go about it right away,as soon as I do,I will be calling Roland.
    I think you have taken my previous post the wrong way,I meant do some research to see if the work is there for it,not to find an alternative method of fixing the machine.
  • Graeme Harrold
    29 October 2008 at 23:41
    Yes the work is out there for practically any venture, the mark between being successful and failure is being able to successfully market your product and ensuring quality above that of your competitors.
    You have been told several time that you have an absolute bargain on your hands once repaired. If you are struggling to afford this minor outlay then you are trying to break into the wrong market. Chances are you could sell that machine tomorrow to someone here and make your money back.
    All of the advice given in both threads has been given in good faith, but you have gotten quite a few peoples backs up with your continued lack of appreciation for what you have. Take the advice given or give up 🙂
  • Ben Dexter
    29 October 2008 at 23:50
    I have clearly stated the advice given is right,and I will be using it
  • David Rogers
    30 October 2008 at 00:02
    quote Ben Dexter:
    Get an engineer in to do the repairs. As it’s sat unused – it’s costing money just being idle. You tried to do it on the cheap & got stung.
    Anybody else here would beg or borrow a grand to suddenly have a fully working VP300 in their lap…with a warranty! There is ALWAYS a market for digital print…but you have to CREATE it. There’s people on here that probably make a grand a week off their Roland printers without too much difficulty…half a dozen banners and a few sets of stickers will see that…
  • Ben Dexter
    30 October 2008 at 00:49
    Thanks,
    I will keep you updated as to when I get the engineer out.
    you can see some of my previous work at custom-pixels.com
